Windscreen washers not parking - any suggestions?
Hi all
The front (and rear) wipers in my new (to me) 1973 2.4E don't park at the end of their stroke when turned off - they simply stop wherever they are. Otherwise, they work fine.
Any clues as to what could be causing this?
Also, should the rear wiper be single or double speed? It appears to have a two speed switch but only goes one speed (pretty fast) in either switch position.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 07-03-2006, 08:40 PM
Detached Member
Hugh R's Avatar
I cleaned the electrical contacts on my 84 and squeezed the switch tighter with a vice grip and it works fine now. It might be different with your 73 however. IIRC, it wasn't getting a good signal to "park" from the switch.
Hugh
Old 07-03-2006, 10:19 PM
thanks hugh - cleaning all of the connections is always a good place to start
Cheers, Ryan
Old 07-03-2006, 11:49 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Short term, when you turn off the wipers, pull the lever a little forward or back to see if that helps. I have the same problem and it will part them. I must just be a little off on the contacts so it works. When that stops, I will go into the steering column to fix.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 07-04-2006, 04:42 AM
