Air Medal or two
Rear Wheel bearing slop
After "proper install of brand new bearings I am (was ) shocked at all the slop in the axle stubs, But the more I think about it with out the CV joints installed, and torqued, there is probably no way to have snug ball bearing- fit w.o. the preload......right ??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
When I installed my rear bearings, there wasn't any play to speak of. You might try a trial install & bolt the whole thing together to see if you still have some play.
Marv Evans '69 911E |
There shouldn't be any play. I would have to believe that something is amiss. Putting the whole thing together (outer hubs and axles) and torquing the large nut should snug everything up. If you've done that and still have some movement, then something's wrong.
When I did mine a couple of years ago, there was no discernable play. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Somatic Negative Optimist
Mike said it: there should be no play.
Attaching the CV joints has nothing to do with the stub-axle-play. The correct torque for the big nut is around 220 ft-lb and can only be done with a 3/4 drive long, LONG breaker bar. (Unless you have a big impact) Here is how: Wheels mounted without center cap, emergency brake on, in reverse gear, big socket with short 3/4 drive extension, 3/4 drive breaker bar with extension. But, first make sure that the bearings/parts were installed correctly
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Air Medal or two
Yup I think that's the problem I am waiting for "stretch" bolts for the axle stubs and have not install the stub thrue the bearing yet..as said hope when that gets snorqued dwn all play will vanish
Afterburn - what was the outcome for you - ?
Did play disappear or remain after assembly and all torquing? Please share all details, I've got this same problem on one hub after new rear bearing install.. thanks, Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
Yah what "strech" bolts were you refering to?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Air Medal or two
stretch bolts hold the flanges to the differential spiders...as for fixing I have improved it but there is still something more stretched then what I replaced...........I going for all new cv joints next see what that dose..
Wait....the axle is moving in and out? IIRC, the CV joints should have no bearing on that. The inner point of the axle moves in and out of the trans as the suspension moves through it's travel. Something isn't right..were the parts pressed completely?
Excessive play can be a significant issue..the brake rotor will have excessive play which pushes the pads back and makes for a long pedal travel, among other problems.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Afterburn,
You shouldn't have any axial play when pulling the wheel/hub back and forth, but you may have some when rocking the wheel at 6 - 12 o'clock. My bearings have about 1000 miles on them and there is detectable play when rocking the wheel. I can only feel it though when the wheel is attached, not by moving the hub alone. Also, one side has slightly more rock than the other. |
Air Medal or two
Yea thats how this all started -wheel bng slop...thought I would address the other issue s while thereith......20 20 hind sight had the cv joints all apart to do over I would (will) buy new as there is tracks in the outer race where the balls work. I am thinkin that maybe the big deal here (hope) All the work to replace boots and repack old joints just is not worth it-- imo 20 20/ hind sight !!!
