-   -   Tips Requested: Remove Fuel Injection (http://forums.pelicanparts.com/porsche-911-technical-forum/291626-tips-requested-remove-fuel-injection.html)
der Mond 07-03-2006 12:31 PM
I have a new set of engine compartment flexible fuel lines and fuel injection manifold gaskets to install, and have not been able to find posts regarding any tips on removing/reinstalling the fuel injection manifold system as simply and painlesslessly as possible. Tips would be appreciated. Also, after reeassembly, since I'm 400 miles from the nearest dealer, can I have any shop that does emissions inspections check my CO? What are the allowable limits?
Mukilteo911 07-08-2006 03:42 PM
Don't know the answer, but to help you get one I'm bumping your question back to the top.
Jim Sims 07-08-2006 06:59 PM
I've haven't done this task on your exact engine but a few suggestions (warnings): (1) account for every fastener element (nuts, washers, etc.) and have them off the engine before lifting the induction manifold- no dropping a fastener and finding it later (find it immediately - a magnet on a stick is your friend) as you risk having it fall into the engine, (2) immediately plug the openings into the heads as soon as you lift the manifold. A set of 1/4" drive sockets with integral universal joints and an assortment of drive extensions is very helpful in accessing fasteners on the top of the engine. A partial engine drop may be helpful/required to improve access. Hopefully you will get better more specific input from others.
der Mond 07-09-2006 02:55 PM
Thanks for the replies thus far.
Thanks for bumping the thread!
I visited friends in Everett back in the 80's and used to ride a bike down to Mukilteo and watch the cars unload for Whidbey Island. It was then a quiet, pretty place. Wanted one of those license plate rings - "My favorite place: Mukilteo by the Sea."
Saw it a few years back - it will never be the same. But that's how it is these days - by the time the gasoline formulation developments go, my Porsche may never run the same also. But I hope to have a couple more great years with it.
ianc 07-09-2006 05:11 PM
I did this job a little bit ago to replace intake gaskets. It's basically 'just keep taking things off until you can remove the intakes'. Fairly time-consuming, but fairly straightforward as well.
Start with the passenger side as that is fairly easy to remove; once you get it off you'll have more room to work on the driver's side.
Jim is right (as usual) on the fasteners thing. I carefully put every nut and bolt back where I removed it from as I took pieces off the engine. That way there's no question about what goes where during reassembly.
Good luck,
ianc
Jeff Alton 07-09-2006 07:27 PM
This is not too tough, but it will take you some time. Get a good u-joint for your ratchet to get a the barrel nuts that hold the intake manifold on. You do not want to strip one of those.....
I would suggest you replace the insulator blocks between the two gaskets, it has been my experience that this is where a majority of the intake leaks occur.....
I also am sending you a PM....
Cheers
plymouthcolt 07-09-2006 07:34 PM
If you are removing the fuel injection to gain access to the fuel line in the rear, drop the engine.
I removed my f.i. to replace gaskets and oil sender and it would have been faster just to drop the engine.
I secons what Jim said, have a tool to retrieve washers and nuts, plug your intake holes, and make sure it is not windy.
