 Pass Side Aero Mirror ? Does anybody know if the passenger side aero mirror is closer to the body than the drivers side. I installed a set (still can not get the power working correctly) and it seems that the passenger side mirror is a little closer to the door than on the drivers side. Thanks Again for all of your continued help... and support. SmileWavy |
 I don't know about the closer aspect of the location but the passenger side is very different from the drivers side both in the location on the door and the configuration of the mirror base itself. Go look at a factory car with the mirror installed and it will be obvious. |
 Pics would be great.... |
 I think they look fine on the car, I just was not sure if it was supposed to be that way. It looks like it shoud...?http://forums.pelicanparts.com/uploa...1152052770.jpg http://forums.pelicanparts.com/uploa...1152052795.jpg |
 Yes.  Mine are the same.  I think it has to do with the angle of the driver's view of the mirror an the a pillar.  Passenger side is mounted further back on the door and closer in towards the window. |
 I don't have a front shot here but looks to be the same from the rear.... http://forums.pelicanparts.com/uploa...1152114151.jpg |
| All times are GMT -8. The time now is 01:31 AM. |
