Mookster's Avatar
Heater Hose replacement with modern products
I am attempting to clean up the engine compartment and want to replace the OEM heater hoses (brown paper hose with alm lining)with something more modern.
I have seen some photos of engine compartments with people using aircraft heater hose.
Where do you get this stuff and is it safe? What temperature ranges are needed for the replacement hose?
Your assistance is appreciated in advance.
If it has a skirt or tires, it WILL cost you money!
Old 07-03-2006, 04:34 PM
Look up Aircraft Spuce & Specialty Co on the internet. Aeroduct Flexible Ducting, aka SCAT tubing. I think our size is "-10", 2.5" ID. Looks and works good.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 07-03-2006, 05:02 PM
Stuff looks pretty cool. Anybody using it?
For the 2 1/2 pipe I guess its $5.60 per foot.
Old 07-03-2006, 05:20 PM
Zeke's Avatar
Oh yeah, plenty of us have used it. Most of those places sell it in 11' lengths, so 2 people could get together for a purchase. IIRC, each car takes around a 3 footer and a 30 incher. Is that right?
(I had some weird H/E's that took the hose all the way up to near the heat valve box things. So I used it all.)
Old 07-03-2006, 07:14 PM
Aircraft Spruce sells it by the foot. I highly recommend it.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 07-04-2006, 07:05 AM
I have used it as well, but I have one reccomendation... Buy the type with the copper wire between two layers. Yes it is more expensive, but easier to work with. I bought the single layer and the copper wire tends to pop out of the ends where you cut it. If you are not careful it can continue to unravel.
Either way, it does look nice.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 07-04-2006, 08:31 AM
Mookster's Avatar
Thank you.
The second link has the 2 layer hose as recommended.
Old 07-04-2006, 10:20 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What color is the SCEET (2 ply)?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-04-2006, 12:26 PM
