-   -   Anyone running 10" rims up front? (http://forums.pelicanparts.com/porsche-911-technical-forum/291808-anyone-running-10-rims-up-front.html)
JoeMag 07-04-2006 03:48 PM
Anyone out there running 10" rims up front? If so, what fenders are you running?
RarlyL8 07-04-2006 03:51 PM
You can run 10" rims up front on a stock 930 fender if the offset is perfect and the tires are not too wide (255mm would work).
mnmike 07-04-2006 04:07 PM
10 inch...wow
Jack Olsen 07-04-2006 04:34 PM
I run 9.5's with 275's under flares that are almost an inch narrower than a Turbo's. It's a fairly tight fit.
http://forums.pelicanparts.com/uploa...1151624728.jpg
Bill Verburg 07-05-2006 06:02 AM
???:confused: those sure look like turbo flares
Wil Ferch 07-05-2006 08:37 AM
I would think 10" rims are kinda small....maybe from an original Mini Cooper ??? Can't fit big diameter brakes into 10" wheels....
Ohhh...... "width" !!!!!
- Wil :)
mmastro 07-05-2006 09:21 AM
I can only get 9.5" with RSR struts.
