Guest
Posts: n/a
Sunroof Problems
I have a '91 C2 whose sunroof was working until recently. I closed it several times with the engine off, now it only cracks open, but gets stuck after about an inch. Any ideas on how I can fix it and if that's what caused the failure?
What parts or relays should I check & where can I find them? Thank you in advance... ------------------ |
Guest
Posts: n/a
Sounds like a broken roof cable. You might want to have this repaired by a Porsche tech. because it is very easy to scratch the paint on the roof panal if it's not removed properly.
