-   -   how do you adjust the idle on an SC (http://forums.pelicanparts.com/porsche-911-technical-forum/29199-how-do-you-adjust-idle-sc.html)
Drew 10-23-1999 01:12 PM
Can't seem to figure out how to adjust the idle speed on my 79 SC. Is it the large sloted scew with spring on left side of throtle body?
Drew
Hence 10-25-1999 10:46 AM
Yes.
Gonzo 10-26-1999 01:04 PM
So if you turn it clock wise does that increase or decrease your idle?
Hence 10-26-1999 04:21 PM
I don't know, but the easy way is to try it and see! But, to take an educated guess, I would think that if you turn the screw clockwise, you would be "tightening" it (assuming that it is standard threaded, which I'm pretty sure it is), which would reduce airflow, lowering the idle. Turning it out (i.e. counterclockwise) should increase idle.
Brian
Drew 10-26-1999 07:51 PM
In (clockwise) does reduce the speed.
thanks
Drew
