teveo's Avatar
RSR 3.0 Piston/Cyls.. worth buying used?
Hi, I was searching ebay in germany and found a set of used P/C's for RSR 3.0
complete set + 4 extra pistons
what kind of problems would you usualy find on these, I mean.. what would be worst case for buying used cylinders unseen.. out of shape with piston slap? if so.. I can get cheaper paperweights locally!
(there are som pix in the auction)
Perhaps someone else has a need for a set, seems to be out of stock in most all parts houses as well!?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=300002101240
disclaimer: I have no connection to this seller.. just stumbled across these.
"old cars and bikes"
== System architect & developer
Old 07-06-2006, 10:21 AM
Why not "certify" all the critical dimensions.....diameter measured at 90 degree intervals....ring and land height/depth, etc.....get it measured and written down as "certified correct" and use it a warranty/ gaurantee for the sale?
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-06-2006, 10:37 AM
Doug Steinel's Avatar
careful buying used p/c
Wil is right. Make sure both the p & c are within spec. I once used a used set out of spec in a rebuild. Burned so much oil you had to change the plugs every 200 miles. What a waste of my time!
77 911, 3.0L
Old 07-06-2006, 10:49 AM
