Ayo Irpin, Ukraine!
70SATMan's Avatar
Question 70-71S undercoating
What, if any, factory undercoating was on the original aluminum license plate panel for the 70S? Anyone with an original 70S care to feel under their panel?
I know the bumpers had undercoating.
I'm looking at an aluminum panel that is being reported to be totally original.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 08-05-2006, 03:23 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Hmmmm???
Old 08-06-2006, 09:05 AM
Gearbox's Avatar
I just had taken my 100% original unmolested 71S apart for resto and noticed that there is no undercoating at all on the back of the license panel. Only the original red paint over white primer. Plus, it's aluminum which doesn't rust and being so close to the muffler, I wouldn't think undercoating would be a good idea anyway. Hope this helps, Allan
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 08-06-2006, 10:24 AM
pwd72s's Avatar
Alan nailed it. No undercoating. The factory replacement panels come primered, the repop pieces I've seen are left in shiny aluminim.
Old 08-06-2006, 10:28 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Thank you guys!
Old 08-06-2006, 01:26 PM
pwd72s's Avatar
Michael...you still may be looking at an original panel, if aluminum. Dealerships were known to do their own undercoating back in the day, and it ended up being sprayed in some pretty silly areas. I recall one VERY POed owner of a trombone cooler car. The dealership bozos had undercoated the oil lines and the cooler! Not exactly the best for heat transfer... If you see primer under the original paint (or the undercoating) you might be looking at an original panel.
Old 08-06-2006, 03:58 PM
Party Member
viejopatron's Avatar
I have a 71T that's the last 1971 D-programme 911T coupe built at Stuttgart and it's coated. Tangerine paint (original color) is under the coating.
However, the car was originally sold in Michigan and the coating could have been added there.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 08-06-2006, 05:19 PM
