der Mond's Avatar
Question Blower Duct Removal Question
Is it possible to remove the hard plastic “hot air socket”, P/N 930 211 323 01 which runs from the engine compartment blower to the air duct that covers the top of the engine, without disassembling the engine? I assume this is the duct that the blower uses, when in reverse mode, to cool the engine. I’d like to get it out of the way in order to pull the fuel injection manifolds.
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 07-05-2006, 11:10 PM
Sports Purpose 911 Driver
mjshira's Avatar
I think you can. However, I'd suggest posting a pick so that people can better orient themselves to your question.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 07-06-2006, 05:51 AM
Friend of Warren
Yep, I used to pull it off every time I changed spark plugs on the driver's side. As I recall it is one or two screws on the blower end and a hose clamp on the shroud end.
Kurt V
Old 07-06-2006, 06:26 AM
der Mond's Avatar
Kurt,
I'm talking about the flat piece with the rectangular white Shell Oil sticker and the rectangular yellow A/C info sticker on it, not the round tube that runs from the heat exchangers to the blower. I'll try to upload the photo.
Dennis
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 07-06-2006, 10:32 AM
mjshira's Avatar
yes, that can be removed without issue. you can run your car without it. some do just that to remove some cluter from the engine bay.
good luck
Old 07-06-2006, 10:41 AM
