-   -   RSR 3.0 Piston/Cyls.. worth buying used? (http://forums.pelicanparts.com/porsche-911-technical-forum/292083-rsr-3-0-piston-cyls-worth-buying-used.html)
teveo 07-06-2006 10:21 AM
Hi, I was searching ebay in germany and found a set of used P/C's for RSR 3.0
complete set + 4 extra pistons
what kind of problems would you usualy find on these, I mean.. what would be worst case for buying used cylinders unseen.. out of shape with piston slap? if so.. I can get cheaper paperweights locally! :)
(there are som pix in the auction)
Perhaps someone else has a need for a set, seems to be out of stock in most all parts houses as well!?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=300002101240
disclaimer: I have no connection to this seller.. just stumbled across these.
Wil Ferch 07-06-2006 10:37 AM
Why not "certify" all the critical dimensions.....diameter measured at 90 degree intervals....ring and land height/depth, etc.....get it measured and written down as "certified correct" and use it a warranty/ gaurantee for the sale?
- Wil
Doug Steinel 07-06-2006 10:49 AM
careful buying used p/c
Wil is right. Make sure both the p & c are within spec. I once used a used set out of spec in a rebuild. Burned so much oil you had to change the plugs every 200 miles. What a waste of my time!
