Bonnie
Guest
Posts: n/a
Oil Pressure 3.2
My UK spec 88 Carerra runs at around 4.2 bar (on the 0 to 5 bar gauge). I've read elsewhere that it should be 7 bar (off the gauge??). At idle, it drops back to 2.5 bar. I guess these figures represent 59psi and 35psi. Does this seem about right or is it running a touch low. My mechanic reckons not to worry as the gauge accuracy can vary wildly from car to car. Any opinions?
Old 11-04-1999, 08:47 AM
Lee Wister
Guest
Posts: n/a
Factory oil pressure spec's. are approx. 4.0 bar @ 5000 rpm at 90 degrees C. As long as your oil lamp does not come on at idle when hot, there should not be a problem.
Old 11-04-1999, 09:36 AM
Bonnie
Guest
Posts: n/a
Thanks Lee. No, the oil pressure light stays firmly extinguished at idle. Seems my pressure is pretty close to where it should be. Thanks for the reply....I appreciate it.
Old 11-04-1999, 10:23 AM
