-   -   Very technical MFI question.... (http://forums.pelicanparts.com/porsche-911-technical-forum/292246-very-technical-mfi-question.html)
Zeke 07-07-2006 11:00 AM
I have opened up two MFI pumps to find the same situation, namely a pin that appears to want to be in the hole in the adjacent arm.
http://forums.pelicanparts.com/uploa...1152295154.jpg
Look to the top there and see the pin or small shaft resting on the top of the arm. Logically, it would seem to go in the arm. But two in a row makes me want to ask.
BTW, this is a 2.4 T pump that is frozen (rack won't move) and Berryman's doesn't seem to help so far. It is for sale as a core if anyone needs it. I will post as such after I figure out what's up on the rod or shaft, or whatever you want to call iit.
304065 07-07-2006 11:49 AM
Milt,
You are inside the forbidden temple!
http://forums.pelicanparts.com/uploa...1152298025.jpg
I don't think that hole goes on the arm. But I don't have the pump in my hands.
Jays72T 07-07-2006 12:09 PM
Interesting, I've have never seen the inside of a pump. It does seem like the pin would belong in the hole on the arm but I don't know what they do.
I do have another 2.4T pump but don't really want to crack it open.
Zeke 07-07-2006 01:12 PM
Originally posted by john_cramer
Milt,
Nah, I have half a mind to tear this thing down completely and see all there is to see. People talk about how sensitive these things are and they are made hell for stout. The pin, shaft, rod, whatever lines up with and fits the hole perfectly. I have the CMA and the Repair Manual downloaded from our host. It didn't give me a clear indication on this (same as above scan). Also, if there is a spring that belongs on the other end of this shaft, it's missing. That seems to be what they are saying, unhook the spring. There are so many damn springs and levers and gizmos in here that it's hard to figure out what they are referring to.
What happened to this pump is it sat on top of a motor that spun a rod bearing. It sat outside in the weather, but the internals look terrific. Me thinks the fact that it is frozen is due to the varnish left over from the fuel and bearing frazz that undoubtedly went thru the oil system and ended up in the pump. However, I didn't see the usual bearing material in the oil that came out of the pump, just some black oil that indicated that the owner didn't care too much about maintenance. It's probably not worth much in this condition.
HawgRyder 07-07-2006 01:28 PM
I have had my pump apart before...I believe you are correct, the pin goes in the slot or hole as the case is in your pump.
Don't worry about the others saying not to take it apart, go for it, become an expert, then answer questions of others when they get stuck.
Bob
Bobboloo 07-07-2006 01:35 PM
Looking at picture #14 that John posted you can see that the shaft doesn't belong in the hole. The shaft appears to be a stop for the lever which is in the away position in #14.
304065 07-07-2006 01:44 PM
Milt,
You wanted a river to cross, this is it. As far as I know, nobody has prepared a concise set of instructions for actually opening one of these up, fixing it, and putting it back together.
The tools to do this fit your need for the unobtainium, too!
As far as them being robust I offer the below. . .
http://forums.pelicanparts.com/uploa...1152305081.jpg
jkarolyi 07-07-2006 04:38 PM
Milt, had my MFI pump apart on a '73 911E and it looked just like that. Soaked mine in Berrymans (soak it for a week!) and if finally roared to life. So I'm pretty certain it doesn't belong in the hole.
Jay
boxster03 07-07-2006 07:46 PM
Like a Swiss watch, ever tried taking one of those apart and putting it back together.
Zeke 07-07-2006 09:05 PM
I won't disagree because I don't know anything. However, I have to point out that if not in the hole, then the shaft flops around and does nothing. As a "stop," it just rests on the roof of the pump. In the hole it makes a teeter-tottor out of the top bar balancing between the altitude compensator and the air thermostat. As such, it has an influence on the next bar down which, in turn, has an influence on the rack. I'll wait and see until everyone has had his say. ;)
69911e 07-08-2006 06:28 AM
The pin belongs in the hole. That pin provides the input for barometric pressure compensation.
ED
69911e 07-08-2006 06:59 AM
Milt: I am glad to see you are still playing with Porsches. I have admired your attitude of having fun with the cars without concern for going along with the crowd.
Here is a picture of the inside of my pump.
http://forums.pelicanparts.com/uploa...1152366478.jpg .
There is not much to worry about if you want to take apart the pump to fix or modify. As long as you have 2 pumps, one can be used (as you have done) to verify how it is assembled. The only adjustment which I wouldn't touch is the adjustment for each piston to change the correlation between individual cylinder fuel delivery. I think you would need a special setup to calibrate this.
ED
Zeke 07-08-2006 07:32 AM
ED
The one pump I have (the T) has been worked on before. There is a spring missing, that I have verified. Probably ran poorly, I don't know. AFA the individual correlations, I noticed that the previous intruder made witness marks with a scratch awl to get them back to where they were. The special tool you talk about is a bench tester where the pump is run and the output is measured precisely and calibrated. I would enjoy this sort of work but I'm not buying a bunch of testing equipment. I have enough stuff as it is. :D
Thanks for your answer about the rod. After looking at it for a long time, I couldn't imagine it being loose and having any function. I have already inserted the rod into the lever/arm on my E pump which I am planning to run.
(What do you mean you're "glad to see you are still playing with Porsches"? Wa'd you think I was playing with?) ;) :D ;)
Early_S_Man 07-08-2006 12:04 PM
Milt,
That pin & lever seems to be part of the baro-cell and warmup thermostat linkage. As you surmised, it seems to need the pin in the slot of the lever ... according to the diagram below:
http://forums.pelicanparts.com/uploa...1152385449.jpg
Zeke 07-08-2006 12:46 PM
Thank you, sir! I didn't get as far as my factory manuals, so thank you for looking that up. I guess I'm lazy nowadays, but I do have the resources.
Don't you (everyone) think it's weird that I opened 2 of these things and they were both apparently reassembled wrong? Makes you wonder about whom you take these to. And, for the record, I have no idea where these pumps have been. That's why I'm skeptical and examining every small detail. I might even understand them before I'm through! ;)
Also, it looks like the T pump is going to be somewhat sacrificed for a couple of small parts. I'll chronicle the disassembly on a new thread for the curious just as I did when I disassembled an MFI fuel injector that was beyond repair.
See the injector here:
http://forums.pelicanparts.com/showthread.php?s=&threadid=203134&highlight=inject or
edited for spelling
jkarolyi 07-10-2006 09:19 AM
Weird. My car seemed to run just fine after re-assembly. I remember seeing a picture in Check, Measure, Adjust that showed the pin as being out of the hole. I'll see if I can track it down.
Edit: Not in CMA...it must have been some other publication that describes how the MFI system works.
Zeke 07-10-2006 09:44 AM
No, it's not in the CMA. You might also have the download "Repair" where the above pics from JC came from. However, there are dark areas and shadow that prevent one from clearly seeing the shaft. What's more, the sequence has one taking out the altitude compensator early on in the disassembly process. AFAICS, they don't show how to remove the shaft which is on a pivot held by a dinky circlip.
I'll go with what Warren says (who wouldn't? ;) ) and also my own observation that the arm will not influence the next operation if not anchored at each end. AFA your MFI running good, I can see that, too. When one looks at the over all effects of this ass'y, I'll bet many racers don't have any of this stuff left in their pumps. It's just too fine of an adjustment to be worried about if you're on it hard all the time. This part of the unit is all about keeping the engine clean running at part load, to the best of my guess.
Thanks to all that replied. I have put the shaft in the hole on my E pump and that's where it will remain. Now, there may have been some info from the factory at some point to disconnect these, I don't know.
edit: Jeez, my spelling has really suffered lately :eek:
Wayne 962 07-10-2006 11:22 AM
Very swiss-watch like. I wouldn't mess around with a pump that you are actually planning on using in the near future...
-Wayne
304065 02-12-2007 06:34 AM
Here is a photo of my spare pump that is now at Gus's.
When the pump gets back I will resolve this issue once and for all. Surely GUS knows how it goes.
http://forums.pelicanparts.com/uploa...1171290657.jpg
Jeff Higgins 02-12-2007 06:47 AM
O.k., just out of curiosity, I pulled the cover off of three spare pumps that I have. Every one of them has the pin above the lever, out of the hole. I have a fourth that is on the car and running, so I really don't want to dig into it, but I guess just taking the cover off can't hurt anything. Two of my pumps have apparently never been appart; one looks like a fresh rebuild with all the lacquer seals on the screwheads and everything, but I don't know its history. The one in the car was rebuilt by Pacific about five years ago and runs great. Maybe I really should look at that one.
Jandrews 02-12-2007 08:42 AM
Curiouser and curiouser! This is very interesting and it will be important to find out the truth. The amazing thing is that it appears we have many examples of both!
JA
Roland911 03-19-2007 02:13 AM
Same situation with my pump.
I have spoken to Koller&Schwemmer (Bosch) in Germany last weekend. This is the company who bought the whole equipement directly from Porsche and are the experts.
They confirmed that the pin hast to stick in the whole.
Roland
Grady Clay 03-19-2007 12:34 PM
Roland,
Thanks for inquiring – nothing like getting closer to the horses mouth (we tend to work from the other end sometime.)
A quick Google produced this link:
http://www.koller.de/
Go to “Kontact” and ask a question.
When I contact German companies, I send both English and a Google translation. Use simple sentences. That way it gets forwarded to someone who can actually answer the question.
Milt, the only reason I didn’t post here is I don’t have a pump apart. Sorry I didn’t make it to LA. Doc appointment change intervened.
Best,
Grady
bavaria911 03-19-2007 02:30 PM
Grady and Roland,
Herr Sattleburger is the man! He speaks English very well.
He rebuilt my S pump and adjusted the T pump ...which I plan to sell in the future.
Vr,
Bavaria911/ Scott
Roland911 03-20-2007 12:36 AM
Grady,
unfortunately the information you get from Koller is limited as they are cleaqrly "protecting" their knowledge.
But:
I got in contact with Porsche Classics in Stuttgart recently and these people are REALLY very helpful as they don't make a secret out of it.
They are responsible for the oldtimer maintenance and the car rebuild work at Porsche.
I met an elder mechanic who is VERY experienced.
He gave us a lot of hints.
Next meeting in May.
Scott,
in the meantime I bought a used MFI pump (from the US), I thought it would be a good idea to have it in order to replace parts if neccessary. In my case I think the flightweight mechanism isn't working properly. Too expensine to repair...
Hopefully I get the problems in the part load area now under control.
Roland
Jim Richards 05-28-2007 01:23 PM
I pulled the side cover off my injection pump today and found that the pin was not located in the hole of the lever arm.
http://forums.pelicanparts.com/uploa...1180383732.jpg
Is it difficult to remedy this?
edit: After looking at john_cramer's post of the disassembly procedure and Warren's post of the pump internals, I think I should be able to correct this. I hope this will help my rich running condition that seemed to be a bit worse when we were at greater altitudes on our road trip.
svandamme 05-28-2007 02:34 PM
i've dealt with her Sattleberger for my S pump , found it best to translate things in german before mailing, and have him send back in german as well... wasn't getting anywhere with english mails...
and a typical german to boot, inquire about using 2.2S pistons for a 2.4 and how that would work with the pump and if they could calibrate for that, got back " nein we calibrate for ze exact 2.4S specification!" :D
and yes, they are very protective bout the knowledge...
Jim Richards 08-09-2007 07:27 AM
I've come to the conclusion that it is normal for the pin to rest above the lever, as seen in milt's, John Carmer's and my (2) MFI injection pumps. Here is a pic that Grady Clay posted a while back and it shows the pin resting above the lever (gotta look close). :)
http://forums.pelicanparts.com/uploa...1088275698.jpg
(C) 1969 Dr. Ing. h.c. F. Porsche A. G., Christophorus #79, p. 9, February 1969
In addition, the pin diameter is roughly 0.14mm larger than the hole diameter (as measured on 2 injection pumps). After I replaced my inop barometric cell, I buttoned the pump up, leaving the pin/lever as they were.
Roland911 08-14-2007 12:38 PM
Strange.....I have never seen on pictures that the pin is outside the hole.
I have a contact at Porsche Classics.
I will try to get a final answer from one of their senior mechanics.
Roland
jcge 01-14-2008 02:47 PM
FWIW - in mercedes benz and RSR pumps, the barometric cell is located directly above this lever, and acts directly on it (right where the pin is shown resting on top of the lever in your many photos above) - in these applications, there is no need for the eccentric and pin to transfer the displacement to the correction lever
John
isabuddy 06-25-2011 03:10 PM
I am right now working on my MFI system and highly appreciate all the posts on this board. When I came acroos the pin "in" or on the lever question I took a look at mine (72 T) and it was resting on the lever. So I took a closer look and tried to understand the kinematic situation of this lever and here is my explanation why the pin should always rest on top of the lever:
The end of the lever which is actuated by the thermostat is guided in a linear slide (plunger type). If the pin was in the hole that would force a circular movement of the lever on the thermostat side. This would either destroy the plunger slide or prevent the thermostat mechanism from working properly. I thought that this is important to know for everybody so I put my first post after years of reading.
Bobboloo 06-29-2011 08:53 PM
This could be one of those situations where a design was altered from it's original blueprint but the hole still remains from that original blueprint. Possibly for the reasons you've outlined.
Thanks for adding your thoughts on this.
Wayne 962 06-29-2011 09:48 PM
I've always maintained that the pumps were way more complicated than the engines themselves!
-Wayne
j911brick 04-08-2014 08:30 AM
Thought I would bump this for the sake of possibly new information.
