Guest
Posts: n/a
gearbox
Can I install a carrera 3.2 on to a 1974 916 gearbox?
Guest
Posts: n/a
If I understand this correctly, you want to
put a 3.2L in your 74 911. In that case, yes, the 3.2L will bolt right up to your 915 trans. My confusion is the reference to the 916 trans which is a hybrid 915 with a flipped ring gear used for mid engine applications. If that is ,indeed, what you have, it too will bolt right up. JPIII |
