Huey58
Guest
Posts: n/a
Tire Pressure
What is the optimal tire pressure for my pirelli P700's? The side of the tire says "max 50 psi". When I put my 911 up for storage, I was told to pump up the tires to 40-45 psi!What was it suppose to be before storage?
Old 01-17-1999, 12:23 PM
EBSwetland
Guest
Posts: n/a
As far as I know my manual says for the front you want 29 psi and 34 psi for the rear. The manual will tell you what the tire pressure should be. I have an '82 Targa.
Old 11-16-1999, 01:14 PM
