gerard vaglio's Avatar
Both headlight out???
Okay, both my headlights are not turning on all of a sudden. Front fog lights won't come on either. All the other lights on the car work fine? 79sc no other electical issues.
So, I guess this is a fuse? Which fuse is it, in the trunk right?
Any other ideas. They were working fine yesterday.
Thanks for the help.
Older cars, sheesh.
Old 07-08-2006, 03:11 PM
Early_S_Man's Avatar
Porsche Crest
Headlamps have four independent fuses ... the common point of failure is the control stalk switch which carries all of the current!
There are temporary fixes by cleaning and filing the switch contacts ... but, ultimately it will need to be replaced! Relays need to be installed to circumvent future failures of this type!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-08-2006, 05:40 PM
Yellowbird RS's Avatar
maybe a short cut check the wires in the steerin wheel column and the left stik (the high head lights one)!
don't ask how I know
X/A
Old 07-08-2006, 05:41 PM
For some reason the headlights are now working again?
I will follow up on suggestions, thanks.
Old 07-08-2006, 10:39 PM
rnln's Avatar
huh? I read a thread here, someone was saying the headlight system in our car doesn't have any fuse at all. That's why he suggested to at a 3amp fuse right at the switch at a pole something like 85L or 86L. This is why I spent all day today working on it and I actually... fried my switch
You mentiioned clean the switch contact. Do you mean headlight switch? Does that mean you can open the internet of the switch apart or you mean just the poles/plugs?
Fat butt 911, 1987
Old 07-08-2006, 11:11 PM
Porsche Crest
rnln,
All 1965 thru 1989 911 models have four fuses for the headlamps! What they don't have is relays to carry the switched current ...
The switch I was referring to that can be cleaned/filed is the control stalk switch, not the main light switch!
Warren Hall, Jr.
Old 07-08-2006, 11:28 PM
dash lighting power wire from sw, not headlights get the 3amp fuse.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-09-2006, 09:35 AM
rnln's Avatar
Does that mean if I install a relay for for each headlight, and foglight, my lighting will be better/brighter.. another project to think about.
Thanks.
Fat butt 911, 1987
Old 07-09-2006, 11:59 PM
This Way Up
rdrr's Avatar
Similar thing happened to me recently. It turned out that a wire from the headlight switch was loose. When I got in the car one day I knocked the wire off the switch completely and - no headlights. Reconnected the cable and all was fine.
Old 07-10-2006, 12:08 AM
Porsche Crest
rnln,
Generally, yes, for the headlamps. Fog lamps already have a relay.
Reliability will be enhanced over what left the factory ... a ticking timebomb waiting to fail! Losing all of your headlamps at night , many miles from home or civilization is no laughing matter!
Warren Hall, Jr.
Old 07-10-2006, 12:42 AM
