The forward/backward movement on my 8 way driver's side seat has just bugged out... I hear the motor noise, but no movement.. other adjustments work fine...
Any suggestions? Ready to pull the seat out and see if a coin or something got in the track... Thanks! Patrick
1987 Targa Carrera Granite Green Metallic Daily Driver Pulls in 5th gear-Amazing! http://www.pelicanparts.com/gallery/speccarrera |
Electric Seat Drivers Side- Forward/Backward Failure
I just had the same failure in my 88 911 Carerra -- driver's side also. Wrench told me the switches, backward, forward, were out. The dealer said they were $100 each, but you can find them for cheap on ebay.
Ah, will check em out... thanks for the info.
GFCC
Spec, There is a threaded rod that spins with a matching sleeve that moves the seat for and aft. If your motor turns, it sounds like the sleeve came off or broke. You need to remove your seat to look at/ repair it.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Check to make sure that the bolts securing the seat rails haven't backed out.
I'm with C U L8R on this one cause the motor still works when the switch is pressed.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
ok, will do. will take the seat out and check the sleeve and the rail bolts from all the .95G's I've been pulling!
Thanks for the input everyone.
Banned
hey Spec, my '88 930's driver seat has just come down with the same flu symptoms your Targa had. Did you fix the problem, if so what did you need to do?
I also can hear my motor/switch working but there's no movement only from the side closest to to the shifter. The left side near the door does move, but it makes the seat distorted so I am careful not to touch the switch as to not break the seat. any helpful info is much appreciated. Eddie |
I looked at the motor assembly, and see the two white plastic gears spinning.. they should be engaged I presume... the motor works...
Taking the car over to TRE Motorsports in NH soon, so will see if I can get them to fix...
Banned
ah so you were not able to remedy this ?
Not yet--I tried jamming a screwdriver to try to move the gear over, but will see if TRE can fix it... don't want to crack gears. When they fix will post on how it's done... the two plastic white gears are located in the front of the seat area-- visible w/o removing seat... I see em spin when I push the button, so they are just not connected and not driving the seat back and forth-- pretty sure that is problem...
Check the flex cable running from the left and right side of the motor to each respective side may have pulled out, I'll bet on it, Johnny O
Thanks JohnnyO,
Will do... glad switches and motor works! This sounds like an easy fix. Patrick
Yep, JohnnyO- that's exactly what the problem was.... the left side was out...
All I did to fix it was 1) look under the front part of the seat, locate the thick rubber 6" hoses that insert into the middle box, 2) pull out one side, (the box where the two nickel sized white plastic gears insert is easiest), 3) follow it back to the left side rail where the other end inserts.. the left side is probably the most common that comes out--- I didn't have to remove the seat at all.. just use a flashlight and when you remove the rubber sheathing, there is a wound wire inside with square ends on either side.. when you push the buttons to move the 8 way adj. seat, the motor spins the wire inside the protective sheathing attached to gears that move the seat... The square ends fit into the the top box (look for hole) and on the left side of the rail, you will see a small round bracket that guides the rubber hose cover at an angle to about the other end gear which is about 8" from the front rail... It's really simple-- I though I'd have to pull the seat and take the railing apart-- presto! Working seat again--
Banned
I give up!! Ive been in the garage for over an hour eyeballing under the seat and cant find any loose or disconnected wire. I have an '88 930. Are the seats different than a normal Carrera?
I have the Bentley book and it doesnt help any either. Looks like Im going to have to pay up$$ at the dealer. |
speccarerra, good for you, just be sure if only the one side was off the wen you reinsert the cable the the seat is square and that the left and right sides are equadistant and not cocked this will put a strain on the front and back movement, johnny o
GFCC
diabolos88, Where are you located? I thought I saw you write that you were in the Phoenix area. If that is the case you could swing by my house the saturday after next and we could take a look at it. There will be a few other pelicans here, we are getting our cars ready for the April 22nd track day at Firebird. Let me know and I'll send you contact info.
Diabolos,
Don't think seats are that different... I wonder if there is a front cover over the two cables and middle gear box??? I pulled some pics from a LA based porsche salvage shop- see the tan seat on the left-- it has the two black hoses that house the wire cables running into the middle box with the plastic gears... they may look seated, but I removed one by one, the rubber housing, reinserted them and tested to see if it turned...
1987 Targa Carrera Granite Green Metallic Daily Driver Pulls in 5th gear-Amazing! http://www.pelicanparts.com/gallery/speccarrera Last edited by SpecCarrera; 04-06-2006 at 04:14 PM.. |
Another 8 way adj. seat on the left.. the black one with the box of rubber gloves on it... can clearly see the black hoses going into the middle gear box...
Patrick
Banned
![]() Spec, I see the box upfront, that box on mine has aplastic cover that was keeping it hidden. But I still cant get in there cuz the seat stopped moving right where it keeps me from getting in near the footwell area, Im an ex bodybuilder, 265lb / 6'3" so its a tiny tight spot to get into right now. If only I could manually move the seat back a little, but Im afraid of breaking the teeth or the gears on the seats. Can someone help me out here, preferably someone locally who would be able to squeeze in there? It sucks driving it because my legs are up to my throat! arrgh! |
