you see Arthur...
gauges
Just installed a new aftermarket sterring wheel. I think it looks great. Anyway, with the smaller diameter, I am having trouble seeing my speedo and tach. I have seen gauges that are twisted so the redline is at 12:00, how do I do this for my tach and speedo? Thanks in advance.
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
Work in Progress
If you are doing this to an SC it is really easy. All you have to do is carefully pull them out literally just pull on the gauge it is not held in with anything more than a rubber gasket, turn them to your desired angle and push them back in.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
you see Arthur...
thanks. That sound super easy. I will give it a shot. Thanks again
When I did mine I had to use a wide putty knife to get them started before they came right out. I put duct tape on the corners so I didn't scuff the dash when prying. It's easy though. Once you get one out then you can reach in and push the others out from the back.
Good Luck!
Bill 997.2 |
You can push from behind to get them started. You should be able to get enough of your arm in there past all the ventilation plumbing and give them a nudge.
I rotated mine, then eventually sent my tach to NH Speedo for this treatment:
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
For Porsche quality cars... I always felt rotating the gauges was a "kludge" fix..I'm sure guys do it not just to "functionally" get readability...but also to "look racy".....
Imagine, the turn signals pointing up and down !!! ..... etc. GeorgeM's fix....costly... is the right way to go ! .... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
you see Arthur...
George M, your tach looks great. Don't know if I will be able to get my big mitts behind all the ventilation plumbing to give them a small nugde, but we will see.
Thanks,
you see Arthur...
Wil,
It didn't even occur to me about the turn signals. Maybe my rotating of the gauges will only be temporay until I go down the same path as GeorgeM.
This Way Up
I found it easier to get the clock out first, then reach through and push the rest out..
