Guest
Posts: n/a
Bulb Socket for 911
I got my 911 Targa a month ago and noted that the front left turn signal was not working. There's two, the one further back is not working.
I pulled the assembly to change the bulb, and lo and behold, the entire bulb, socket and wiring points are corroded clean through. Pelican doesn't seem to carry this part...any ideas short of hardwiring (soldering) a bulb in? thanks - ------------------ Mark Szabo 1986 911 Targa 3.2 |
Guest
Posts: n/a
Try a Porsche dismantler such as AASE bros or Parts Heaven you can go to PLatz.com and their will be a listing of them The part would probably be less than paying someone to fix it.
