-   -   My first time to use a bra! Help!! (http://forums.pelicanparts.com/porsche-911-technical-forum/29291-my-first-time-use-bra-help.html)
Scott Kail 12-06-1999 06:00 PM
Today I received a 2-piece, Colgan bra for my '77 911, which I bought from an individual. As expected there was no instructions. 1) Where should the straps inside the trunk be fastened? 2)Once everything is in place the trunk will not fasten! Thanks for any help.
jryerson 12-06-1999 07:47 PM
I fasten the 2 straps at the same spot on the firewall cowling .Their is a little metal tab on the top you can hook them both too
Their should be an allen wrench with the bra you need to take off the 2 platic plugs that cover the lowet hood latch and loosen the 2 bolts with the allen key and move the latch up some so there will be more of a gap when you close the hood with the bra on
