Guest
Posts: n/a
Rough idle when oil temp. high
I have a '87 Carrera and has 130k on the clock. Recently, the idle is rough when the oil temperature is a bit above 90c. It goes up and down around 1000rpm. I'm also thinking to add a front oil cooler to it. Has anyone experienced with any brand on this kind of oil cooler? Any input would be appreciated.
Guest
Posts: n/a
First of all, 90C is perfect. Your idle problems could be simple matters of adjusment.
Have your idle CO adjusted and possibly have your base idle speed set. Joe |
