930 axle upgrade
Pelican's
I recently broke a CV on my 71' 911 racecar due to putting 300+ hp at the wheels thru a 911 axle setup. While the smaller cv's/axles have served me well the last 10 years, it is time to upgrade. The question is, will the turbo stub axles fit into a late 911 trailing arm? I know the drive flanges on the 915 box can inter-change to the larger 108mm version, but what about on the trailing arm side? Also, does anyone have a set of inboard/outboard drive flanges they want to get rid of? I aready have the 930 axles and cv's taken care of. Thanks! |
hmmmm. You happen to have Bruce Anderson's 911 performance hand book? It shows pic of 930 rear trailing arm and non-turbo one. The stub axle area looks much longer on the turbo.
930 stubs and axles are shorter than Carrer/915 ones and canot be used outright. 930 rear suspension arms are totally different than SC/Carrera ones, so it will take lot's of modifications in order to use 930 pieces.
I suggest changing stubs to 108mm Carrera ones and using Carrera halfshafts. They are cheap, bigger than 915 ones and outer CV's are one-piece so there is no torquing/repackning that has to be done. |
| All times are GMT -8. The time now is 12:29 PM. |
