-   -   How to remove oil line from side of motor? (http://forums.pelicanparts.com/porsche-911-technical-forum/293133-how-remove-oil-line-side-motor.html)
rs6er 07-12-2006 07:23 PM
I'm backdating my oil lines to install my SSIs. I can't really get the oil wrench on the nut where the line enters the motor. What can I use?
Early_S_Man 07-12-2006 07:34 PM
Very large 18" - 20" Crescent wrench ... make sure the jaws are tight on the fitting -- no play whatsoever!!!
Joe Bob 07-12-2006 07:37 PM
For the tight areas....Campagnola or Park Bicycle open end wrenches.
rs6er 07-12-2006 08:22 PM
If got a n oil wrench I got from Pelican, but I can't get the thing to budge.
Early_S_Man 07-12-2006 08:30 PM
John,
That's what I encountered when upgrading my system to a front cooler, and I used a big 20" long Crescent wrench to loosen the nut! No harm to nut, and I used a much smaller 36 mm wrench to reinstall it back on after modifications, later.
Joe Bob 07-12-2006 08:31 PM
Heat and a counter wrench....and/or a slip over pipe.
safe 07-13-2006 02:20 AM
Are there ever any problems with removing the line from an mag case engine? Damaged threads etc?
