steersdad
Guest
Posts: n/a
Parts ID
Christmas came early. Just bought my first Porsche since 1976,this one a 71 911 T Targa. Been sitting for 5 years, and has a nasty oil leak when filled, run, then left to sit. I suspect return tubes.
Main problem is Engine Identification. Previous owner bought the unit from a used car dealer, drove it 1500 miles, then there she sat. I suspect because of the oil hemmorage. Decal on the fan shorud indicates it's a 1974, however number stamped on engine block is 6144144. Nothing else.
Any ideas what this engine might be, or where I might find out?
Also, it came sans battery. I purchased one from Sears which comes close to fitting. However, red cable goes to chasis, black off to the starter. I'm going to sounf like a wuss, but I never did anything to my first Porsche (a 75 914) except put gas into it. Is the 711 911 a positive ground system? Fortunately, I've been clever enough not to hook up the battery.
I'm looking for some frienfly advice.
Doug Steers
Old 12-14-1999, 07:36 PM
Tim Polzin
Guest
Posts: n/a
The third digit is the year of manufacturer, so the number makes it a 74. Check the engine number which should be something like 911/97 and is located on the horizontal surface just behind the serial number. If it is not 911/97, post it and someone will look it up. If it is in fact a 74, it's probably a 2.7.
Just a bit of advice before you get too much farther. Buy a Haynes Manual and a copy of Bruce Andersons "Porsche 911 Performace Handbook".
You should be able to see where the oil is leaking from. Return tubes do leak, but not lots at a time. Pay close attention to the head studs where they are mounted to the case as the 2.7 had a bit of trouble with them pulling out.
The ground is negative. The black line with a couple of smaller wires is your positive. The negative should be connected to the chassis just over the battery box. If you bought a side terminal battery, it will just fit in the box, but very tight.
Good luck with your new purchase.
[This message has been edited by Tim Polzin (edited 12-14-1999).]
Old 12-14-1999, 08:45 PM
joran
Guest
Posts: n/a
hi there
the numbers 614001-6146625 belong to a
G - type 911/92 engine
this was built in 1974 and has a 2,7 litre disp.
and about the battery i agree with tim polzin. if you any more info just mail me
may the porsche be with you...joran
Old 12-15-1999, 08:37 AM
