Throttle pedal stuck!!!!!!!
Had a bad night. I was showing off for friend when the throttle pedal stuck at about 5800 RPM. The engine bounced off the rev 3 times before I could shut it down. . The motor is now making alot of valve noise and is not reving as crisply. Broken rocker arm? Do I have to tear it down to check it out?
TODD (the past):
1981 911SC (Rosewood Metallic)
1992 Saab 9000 Turbo
1991 RX-7
1987 VW GTI 16V 1984 Mercedes 300SD
Old 06-28-2006, 10:36 PM
87coupe's Avatar
I'll let the experts give you a diagnosis, but I think the best thing to do when this happens is brake hard to bring the rpm's down and then kill it with the key. Just a thought.
ßrandon
Old 06-28-2006, 10:40 PM
Fleming's Avatar
Replace the throttle rod bushings next to the accelerator, the linkage tips over and catches on the tunnel.
Sorry about your buzzed engine...
Bob
Old 06-29-2006, 06:43 AM
wcc wcc is offline
wcc's Avatar
What's your redline? My '85 is at 6250. So if you were at 5800 you weren't even at redline. That's ok. But you bounced it off the rev limiter 3 times which isn't good but at least it worked. The whole point of the limiter is to prevent damage. So it doesn't sound like to me that your damage was a direct result of this incident.
Are you sure you weren't having problems before? Sometimes when something like this happens we start listening closer and hear things that were there all along and now think we have a problem.
+1 about replacing bushings and/or rebuilding pedal cluster.
The reason it doesn't feel as crispy could be related to the bad bushings. So I would replace those first and see how the engine revs.
Good Luck!
Bill
997.2
Old 06-29-2006, 06:57 AM
Driving member
jester911's Avatar
I don't know if your car has cruise control but that is what stuck my throttle open a couple times before I figured out what it was.
I ended up cutting the cable to it since the thing never worked from day one.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 06-29-2006, 07:03 AM
What's Facebook?
turborat's Avatar
Problem 1 - Replace your pedal bushings. The throttle pedal probably got stuck on the clutch linkage just inside the tunnel. The bushings are plastic, get brittle and break. This happened to me going to turn 6 at Road Atlanta. I rebuilt the entire pedal cluster with brass bushings.
Problem 2 - On my '78 SC, I am told that the mechanical rev limiter resides in the ingnition distributer. I have also been told on more than one occasion that the distributer can be damaged if the rev limiter is activated too many times. I suspect you may have a problem with the distributer and it may be simple to fix. I would not suspect engine damage.
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 06-29-2006, 07:37 AM
cycling has-been
bkreigsr's Avatar
drain your oil & look for metal, replace your oil filter, cut it apart, then look for metal chunks between the folds of the paper.
anything bigger than a fingernail clipping probably indicates time for immediate rebuild.
Old 06-29-2006, 07:54 AM
vash's Avatar
me too. scared the bejeezus out of me. i would just need to bump the CC stalk and it would rev to the moon. i also disconnected it and zip tied the cable to the side. the entire thing is coming out soon.
i think overrev damage is bent valves. good luck friend.
poof! gone
Old 06-29-2006, 08:00 AM
MBruns for President
JeremyD's Avatar
Mine did that too going into the hairpin at sebring at about 120mph
It caused a little bit of a pucker factor...
Old 06-29-2006, 08:32 AM
I need to drop my engine to replace the shift rod, so I'm planning to remove the valve covers and check out the rockers. I have read quite a few times on this site of missed shifts causing broken rockers or bent valves. I suppose a leakdown test is in order.
Any other suggestions as to troubleshooting this issue?
TODD (the past):
1991 RX-7
Old 06-29-2006, 03:39 PM
3 restos WIP = psycho
kenikh's Avatar
My car did this. It was the result of a backed off throtttle stop under the pedal which allowed the throttle arm to move to the point that only the thottle linkage was acting as the stop. The throttle arm eventually deflected to the right and underneath the tunnel, sticking the throttle wide open. I was bouncing my car off of the 7500 RPM limiter whe it happened, but I had no prblems afterward. I got lucky!
Make sure your throttle pedal stop is properly adjusted when troubleshooting. As far as the engine issues go, good luck!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-29-2006, 03:57 PM
It's almost impossible to break the 911 engine while upshifting, or simply hitting the throttle. However, if you miss a downshift and let out the clutch, cause the rear wheels to break traction, etc. then there is almost no limit to the damage that you can do to the 911.
Old 06-29-2006, 06:40 PM
Thanks for the replies. I haven't had the chance to diagnose the problem YET, but I'll yet know what I find.
TODD (the past):
1991 RX-7
Old 07-13-2006, 11:53 PM
Wood Magician
[QUOTE]Originally posted by Fleming
[B]Replace the throttle rod bushings next to the accelerator, the linkage tips over and catches on the tunnel.
Ill second this theory- In fact this happened to me today and luckily the engine was stumbling so I had enough time to hit the key before it over-revved. Ive got a sticky needle and seat in one of the carbs. I had to push my car out of the intersection accross 3 lanes of traffic to get to the side where I pulled the carpet and toe board out and got the bellcrank un-snagged. then I was back on my way...... Lucky
Old 07-14-2006, 01:40 AM
