Super Moderator
Racecar oil-cooler modification
I recently upgraded my engine again and with the new bodywork my temps were climbing on the racecar. On a 90 degree day I was seeing 260 degrees in oil temp.
Obviously the front cooler doesn't do much sitting right against the bodywork and since I'm a cheap SOB I decided to make this on my own rather than buy it. It's fit for my mocal cooler. Cost? $29.99 cheap HF sheet metal brake. $13.99 for the steel. $2.99 for the hi-temp silicone sealant. Plus 6 hours of my labor... The victim (and this will the the second attack on the racecar with a sawsall this year...) Cut out the section for the scoop. Mockup of the sheet metal: Tacked in the pieces for final fit: (The cross brace is "just because") Sealed seams with silicone and primed once I finish welded it.
Looks good Chris. I have been studing how to do this modification for my next project. Thanks for the pictorial!
Jon |
Before I'd go cutting bodywork...I would investigate doing this for front-mounted coolers that are "too close" to the bodywork:
- provide a tight "foam" seal on all "sides" of the cooler...so that the incoming air *has* to force its way through the cooler. Otherwise, it will go around it. No doubt a combo rear-relief cut and edge seal works best, but this would be my *first* try, especially if you're cheap ( as I am). - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Super Moderator
Will, absolutely right, especially if there is some room between the bodywork and cooler.
In my case the cooler was literally right on the body because I'm using a 90 turbo bumper on a 70 chassis... No room for anything there... But I bet with even 1/2" of room and some edge seals you'd be at least partially effective... Jon, Mine is higher than most would want to be because I don't use a hood latch (and consequently removed that whole assembly). Same principle just slightly different layouts. If you don't want to put in the fab time, Pelican offers this Elephant racing part.
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 07-12-2006 at 01:46 PM.. |
I would not call myself "cheap", but frugal
I also have done the bodywork mod in my track car. I left a piece where Chris welded the steel rod. I made an opening at the bottom for exhaust. I made my cover from Home Depot sheetmetal and some pop rivets. Seems to work fine. Lou
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
Super Moderator
Nice. I actually bought the pop rivets and aluminum as that was my original plan... Then decided for structural reasons to use steel/welding, though I don't know if that REALLY matters much...
I'm not cheap, but I am lazy. I was also running too hot on the track with a small cooler in the front, a Carrera cooler in the fender, and a 3.6L engine.
Step 1 was to apply some racing tape to the front grill area. Because I had the smaller of the 2 coolers that Elephant Racing sells, it did not fill up the whole opening. I taped the sides to force the air through the cooler. Still too hot. Step 2: Removed the turn signal on the passenger bumper to get air into the Carrera cooler. I then used a thin sheet of aluminum inside the fender well to funnel the air directly into the cooler by blocking off the bottom and side. Simply zip-tied it in place using the cooler as a mount. Problem solved, even on 100 degree days!
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
Insert Tag Line HERE.....
Venting under the car is soooo yesterday.. Go through, up and over!!
rattlsnak,
That is one SWEET machine....... -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
You guys allways make things look so pretty, here is the poor boys way...
Super Moderator
I thoguht about that, but I'd have run out of space when I needed to install my 27 gallon endurance cell....
b.t.w. we got a new carquest catalog today at the shop and guess who's on one of the cover pictures???? yes, that would be you chris!! sweet!!
Marc |
Super Moderator
What?! Got a scanner? I'd like to see how that happened, lol...
Carquest?
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 07-13-2006 at 07:19 PM.. |
I saw you in the HRP one too!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Super Moderator
Jeff,
I sent them my picture for that one... I'm wondering though if the CarQuest one is really my car as I didn't submit anything to them. If it is me, how did they get it. ?
Super Moderator
Anyone? Buehler? Buehler?
