scott matre
Guest
Posts: n/a
Intermittent speedometer
could use some advice on why my speedo would go dead occasonally. Seems to happen about 2-4 minutes after starting in the morning and lasts about 2-4 minutes. my timing observation could, in-fact, be a pure coincedance however.
87 911
Old 12-18-1999, 05:39 PM
Hence
Guest
Posts: n/a
Probably a loose electrical connection, either at the back of the speedo, in the tunnel between the back seats (there's a connector under the metal panel) or at the sender at the transmission.
Old 12-19-1999, 12:53 PM
Lee Wister
Guest
Posts: n/a
This problem is a sticking speedo head or the sender on the trans. Make sure you replace the hold down clip on the sender!
Good Luck,
Lee
Old 12-19-1999, 04:22 PM
