-   -   A/C question (http://forums.pelicanparts.com/porsche-911-technical-forum/293525-c-question.html)
Joeaksa 07-18-2006 06:46 AM
Originally posted by kuehl
Though I respect that you work with the FAA I don't agree with what you might feel the FAA would do. As you know, since TWA Flight 800 went down off Long Island nearly 10 years ago, ALL the <i>series of events</i> have not been resolved. Yes, the wiring issues are being corrected but the residual problem has not. Why? Cost. Simply a matter of cost. And the FAA has its hands full. There are not enough inspectors or time in the day. I can tell you first hand as I had "worked" alongside the FAA for many years and I setup and ran a Repair Station myself.
And I can tell you first hand that there are a heck of alot of 737's, 757's flying above you that share a common part in the thrust reverser system used on a specific engine, of which I believe may not had been tested correctly by the OEM (demonstrated to them first hand) .... because of a "series of events" misled the mechanics and OE inspectors to believe what they were reading was factual when in fact it was totally incorrect.
<b>So pmajka. I appologize for stepping upon the box and and playing the village screamer. Did you ever get your a/c working?</b>
Kuehl,
I do not work directly for the FAA, am simply an aircraft mechanic who some idiot threw in the cockpit 30 years ago and became a pilot.
Regarding your comments about TWA 800, respectfully the info that the public is being given about this is BS! What the public does not know is that 99% of the airliners and private widebody jets flying today have the same type of fuel tank and pump that was on TWA 800, and not one of them have exploded or caught fire. Yes, one or two of them have had a pump or wiring issue but not the massive explosion that brought 800 down.
The feds and govt deny that the bird was shot down by a missle, even after credible witnesses saw a trail going UP to the airplane. They also cannot really explain the finding of explosive residue on some of the parts of the plane. They can spin it all they want to but the fuel tank/pump is not the problem or we would have had at least one other occurance of the same problem in the last five years.
After being the chief inspector at a repair station, then going to work for many years with Boeing, McDonnell Douglas and Bombardier I have seen things like you commented on regarding the T/R and agree.
PatrickB 07-18-2006 09:36 AM
Kuehl and Joe, again thanks for the wealth of information shared on this post!
Just a quick add... I can only comment on the HC product I have used for the last year. EnviroSafe ES-12a. I believe this product does have a scent added that smells of Pine. If some does happen to leak, one will likely smell it! Joe would probably be able to confirm this...
Joeaksa 07-18-2006 09:43 AM
Patrick,
Yes, it does have some smell added, and was a bear to get off of my hands the last time I changed a can on the hose.
William930t 07-18-2006 05:04 PM
Ok, so is there a non-flammable, SNAP approved R12 replacement?
This product says so, but I am skeptical
http://www.refimax.com/products/fr12.htm
kuehl 07-18-2006 05:49 PM
In a previous post we listed an access point to the EPA approved list, here is the direct link to "approved for auto use"
http://www.epa.gov/Ozone/snap/refrigerants/lists/mvacs.html
And here is the disapproved list:
http://www.epa.gov/Ozone/snap/refrigerants/lists/unaccept.html
FRIGC FR-12, (HCFC Blend Beta), R-416A appears to be on the "approved list" (today).
William930t 07-24-2006 02:28 PM
Anybody out there using FRIGC FR-12?
ruf-porsche 07-24-2006 03:20 PM
Nope
R12 Only
hcoles 07-26-2006 09:11 AM
I hope this question doesn't seem to lame...
I have an 89 911..has been using R-12 and needs recharging about every 1.5 years. R-12 is running about $90/can around here and I might be able to get 3-4 cans for $50/can.
One path being recommended is to "pump" out the system and replace the receiver/dryer and fill with 134a. Mechanic says he has done this with a lot of cars with no known issues.
What are the pros/cons of doing this? What about oil compatibility? R134a has smaller molecule, will leak more? will leak in to passenger compartment more? I may eventually build and replace the barrier hoses...
Advice please. Thanks.
-Henry
scottb 07-26-2006 09:53 AM
Do a search here on the Board. You'll find, literally, dozens of threads on this issue. Some people have had very good luck with R134, but they've modified their systems heavily.
I think most people will tell you to try to stay with R12 if at all possible, unless you plan on doing some serious upgrades to your system.
PatrickB 07-26-2006 10:03 AM
If you have access to r-12, you should consider immediately changing to the barrier hoses. Replace the r/d with a ProCooler model, and then you should have to worry about losing any part of your charge for 5 years or more.... No relation, but check out Renneaire, as they have quite the package deal for the barrier hoses, r/d, compressor, etc...
bigchillcar 07-26-2006 10:33 AM
william,
my last charge was with freeze-12, if this is the same thing that you mean. it worked fine for a month or two last summer, but then the charge went away. in my case, though, i think it's simply because my hoses are old and leak. i need the newer barrier-style hose badly..
ryan
kuehl 07-26-2006 01:16 PM
-Henry
<b>Pro's with R134a: </b>
1) It is available.
2) It is approved by the EPA.
3) Not that expensive per pound.
<b>Con's with R134a </b>
1) It runs at higher pressures as compared to R12 when the ambient (outside temps) are above 85 F or so: which means simply you have to be careful when you charge the system to not overcharge. And you would be wise to have a "high/low" pressure cut out switch installed to protect the compressor and system in the event you lose refrigerant or pressures go high (it temporarily cut's off the compressor).
2) Since the R134a molecule is smaller than R12, and since you are running in high pressures, if you have any leaks, which you do, then you will lose refrigerant quicker. So it's time to break open the piggy bank and get a quality set of barrier hoses.
3) You will have to replace your receiver drier and you will have to add ester refrigerant oil to the system after it is evacuated prior to re-charging. It is most likely that over the years you have lost refrigerant oil anyway.
(These are the basics and there is plenty to knit-pick in between, but you will start to "think" about it logically).
scottb 07-26-2006 06:46 PM
Is it just me, or are we all REALLY lucky to have people like Joe, Charlie and Jim educate us on the ins and outs of 911 a/c?
Guys, reading this thread has been like reading a well-written technical manual. Thanks for sharing your knowledge and experience.
That is all. Carry on!
Scott
pmajka 07-27-2006 06:02 AM
Vent temp is down to 50F when it was 93F outside...After driving for 15 minutes
Oh, what is the Low pressure side supposed to read?
88 911 with stock A/C unit. R12
ruf-porsche 07-27-2006 07:17 PM
Somwhere around 32-36 psi.
PatrickB 07-27-2006 11:03 PM
That seems a tad low for R12? or am I way off (as usual...)
Joe, what kind of pressure are you seeing on the low side with ES12a?
kuehl 07-28-2006 05:34 AM
Vent temp is down to 50F when it was 93F outside...After driving for 15 minutes .......Oh, what is the Low pressure side supposed to read? 88 911 with stock A/C unit. R12
In a perfect world, with R12, assuming everything is stock and every thing is perfect (like my golf game), you can use the following rule of thumb with R12:
<i> Given the range of 18-70 psi on the low side, the corresponding evaporator core temperature will typically be equal in terms of temperature</i> .
What this means is that when you see a low side pressure of say 30 psi, the evaporator's core temperature (not air temp at the vent) will typically be about 30 F.
Questions for you; when you say <i>"Vent temp is down to 50F when it was 93F outside...After driving for 15 minutes"</i>.
1) What is the color of the car?
2) Is it a coupe or cabriolet?
3) How many occupants?
4) Relative humidity?
5) Temperature report at what fan speed?
6) Type of thermometer used?
7) More importantly, what is the temperature near the occupants head?
<center>
<I> 25% of most a/c system problems related to temperature are caused by "air" </i> </center>
hcoles 07-28-2006 06:43 AM
Kuehl,
Thanks for the very good info.
For my 89 911, if I boil down the info. here and go on the path of piece meal approach to switch to 134a here is what I think is a good plan..
1. evacuate remainging R12 and oil and I guess flush/clean
2. install new barrier hoses, smaller dia. type (RennAire)
3. install new r/d
4. install over pressure switch (if I can find anyone around here that knows what that is)
5. refill with 134a and proper oil
see how that works....check pressures, find any leaks
upgrades/fixes
1. if pump doesn't pump good enough...rebuild pump or get a Sanden
2. increase performance by adding Procooler
3. increase performance by adding the better evaporator (RennAire)
is this a good path?
I think the only question I have is....the expansion valve...will that work for 134a? or should it be changed?
-Henry
kuehl 07-28-2006 09:48 AM
Kuehl,
3. install new r/d
upgrades/fixes
-Henry
Sounds like a plan.
You don't have to replace the expansion valve as the superheat settings for R12 vs. R134a are not far apart enough to make a difference that would be worthwhile for the average DIY to struggle with; based on our tests.
Jim Sims 07-28-2006 10:02 AM
"3. increase performance by adding the better evaporator (RennAire)"
I believe Griffith's also sells an improved evaporator - I recall these can be had with a new expansion valve or they are part of the package.
Do not internally flush the existing evaporator without removing the expansion valve first. It is also helpful to externally (air side) flush out or clean (to remove mold, lint, dirt, etc.) the evaporator to improve air flow and heat transfer.
If you have the evaporator out of the housing when reinstalling use self-adhesive foam tape to better seal around the perimeter of the evaporator (to the interior of the housing). This will reduce the shunting of air around the edges and force more through the evaporator core.
Hugh R 07-28-2006 10:18 AM
Regarding Superheat, I cleaned out my expansion valve when I converted to R-134a, don't know why, but I did. Anyway, I had unscrewed the valve in the expansion valve with an allen wrench, I'm not sure I put it in exactly the same. How do I determine correct "Superheat" adjustment. Do I just keep fiddling with it until I get lower vent temps, or what? Any feedback would be appreciated.
kuehl 07-28-2006 03:41 PM
Hugh,
You can find many "stories" on boards and the internet how "I did this and I did that, and I got these results and those results". Though I don't recommend adjusting the valve, here are the basics.
In the auto world there are basically two types of expansion valves or TEV's (thermal expanison valves).
First there is the "peanut" valve, what we find the 911.
The peanut valve can be of two designs, an internally equalized or an externally equalized. The later externally equalized valve is what we find on the OE 911, identified by having two copper tubes coming out of it (I say "what we find on the OE because yesterday I got a call from a chap in tinsel town driving an old narrow body. We assumed he had a flare valve with an externally equalized design but it ended up being an oring type that was internally equalized. So, so much for fantasy). Anyway the top copper tube, aka "thermal sensor coil", is hermetically sealed and filled with refrigerant gas. The end of it has a "pig tail" (or curly-cue) winding which is attached to the TOP (we say "top" again so you know where it should be afixed) of the evaporator's outlet pipe. The pigtail is insulated from the outside world using "tar like tape" (we will call it for what it looks like). In short, as the temperature of the evaporator outlet gas changes the refrigerant expands or contracts inside the copper tube which pushes the diaphram inside the expansion valve which pushes a piston (which is under a pre-set load by the spring). So......piston opens and releases liquid refrigerant into the evaporator. The other copper tube, found on the 911 TEV is the "equalizer tube", it exits the back side of the valve and attaches to the evporator outlet pipe, forming a circuit between the TEV and the evaporator outlet. This feature is required depending upon the pressure differential or pressure drop.
The second type of TEV is an "H" block (looks like a block of aluminium) as found for example on the 928, 964, 993, 996 and onward.
<i>Superheat</i> we'll say is the temperature of the refrigerant gas above its saturated vapor temperature.
You can find plenty of discussions on superheat, however for this discussion think of superheat of the valve in this context: <b> we don't want any liquid refrigerant wandering into the compressor (which will "slug" it). </b> In a perfect world, the refrigerant entering the evaporator should remove as many BTU's as possible without having excessive liquid left behind. Or in easier terms think of running rich or lean.
There are three types of superheat relating to expansion valves or
A) Static
B) Opening
C) Operating
Depending upon which manufacturer's valve you have, the German OE Englehoff or the older CP-Matic, or "US" Parker or import, each has a specific spring rate and may have less or more threads per inch. So there is no "for sure" number of turns per degree of superheat you can turn the little allen head screw. However what is interesting is that when you examine a "new" valve, better yet examine a dozen or so valves or different models, most have the recessed allen screw near the bottom of the valves outlet bore.
Parker for example sets many of their valves based on the "A" static superheat. Turning their valve screw CW - clockwise increases the static superheat, while CCW - counter clockwise decreases it. In their design in "general" : one full turn is about 2 to 4 degrees F of superheat. Valves are usually set from the factory at a given superheat value, say 8 F, or 10 F or whatever based upon the design of the system for each model of car. Valves superheat values for R12 differ from values for R134a, however we have found that the differential between the two settings is not significant enough to warrant a change.
So why would you NOT want to play around or try to adjust the TEV:
1) Most valves are rated in tonnage and frankly there are only so many "tons" you can fit in a system design (evaporator, condenser, compressor match up) in a car.
So you will find that automotive TEV's valves range from 1-2 tons typically.
2) The a/c system is not a perfect working machine. Like your fuel management system in your car, it can only meter out so much refrigerant based on the feed back it gets, and it is nearly impossible to "fine tune" for each given day ; as it is difficult to fine tune each cylinder's character; well maybe not but no one would want to pay the price. So the TEV is like a carb in simple terms.
3) If, for example, you have a few 110 degree days and you want to richen up the refrigerant entering evaporator because it can suck up plenty of heat that day. Once your adjust the valve for extremely high ambients you are kinda left on that playing field. When the cooler days come the valve could be flooding the evaporator where you are not getting the balance of saturation you really need, heat load vs. refrigerant, and the TEV could potentially dump liquid back to the compressor ..... crash. On the other side you could have a valve running too "lean" where there is not enough refrigerant gas and refrigerant oil moving to the compressor to keep it cool and lubricated..... crash.
4) If you do adjust the valve, remember you have to evacuate the system, yank the valve out, tinker with it, put it back in and then vacuum and charge. And then you have to measure the superheat value to see if you achieved your goal (you will need low side service gauge, an accurate thermal couple and a chart). If you are not satisfied with the results you will repeat the process all over again (over and over again). It is not a easy as turnng the screw or rejetting a carb and sticking an AFR sensor up the tail pipe. That is the real PITA.
We experimented with adjusting valves and frankly we found, with our systems, the gain did not warrant a recommedation for our clients to experiment (the Kuehl 911/930 evaporator with its pre-attached TEV works extremely well in southern as well as northern climate zones; there is a "range" the valve always attempts to work in).
You would be better off matching a pre-set valve to your system. Better yet, for the cost of new valve simply put the questionable one in the proper recycling can and buy a new one!
Hugh R 07-28-2006 10:28 PM
Hey Thanks very much for the education. If and when I pull the system, I'll look into another new valve. I guess I shouldn't be tinkering with thinks that I don't understand.
kuehl 07-29-2006 04:20 AM
Reminds me of two things in life:
AFR, and
Women
msk1986911 07-29-2006 05:09 PM
The A/C in my '86 911, converted to R-134 and recently recharged (about 2 months ago), no longer blows cold. I have considered recharging it myself, although posts on this forum haved succeeded in scaring me to point I am hestitating. While just noodling around, I removed the blue and red caps from the compressor. In both cases, I heard a pressure release sound. Is that normal, or is that an indication that whatever refrigerant may have been present has gone? Also, I'm not sure I understand the comment about hooking the refrigerant to the wrong line; it appears as though the two valves on the compressor are different sizes.
Many thanks as always.
Mike
Jim Sims 07-29-2006 07:03 PM
The R-12 systems allow the wrong hook-ups to be made. The R-134a standard fittings are different sizes, the high pressure side is larger and sometimes has a red dust cap. The low pressure side is smaller and sometimes has a blue dust cap. Indeed, if one is using standard R-134a fittings they cannot be mixed up. The hiss of gas indicates you still have refrigerant pressure.
However there are other causes for no cooling other than being low on refrigerant and if you're truly down only two months after charging you have an excessive leak somewhere.
However, you should check to see if the compressor clutch is engaging before tinkering with the charge. With the air conditioning turned on high fan and max cold, is the clutch center (face) turning in addition to the pulley? If not, you may have a clutch or wiring or temperature switch problem. Watch out for moving belts while making this check and don't run the A/C for more than a minute with the engine deck lid up.
ruf-porsche 07-29-2006 07:06 PM
GOOD ADVICE
WPOZZZ 07-29-2006 07:15 PM
GOOD ADVICE
n00b here is used to working on BMWs, so can you clarify why you don't want to do that? Also, wouldn't that make it difficult to recharge the system at home?
Jim Sims 07-29-2006 07:31 PM
Deck lid mounted condenser is cooled by air inducted through the deck lid grill by the engine fan. If the decklid is up, there is no air being pulled through the condenser and high side refrigerant pressures can get very high. On a hot day they can get high enough to blow a hose or damage the compressor. Many of the Porsche OEM A/C set-ups do not have a high pressure shut down switch (although per EPA regulation shops are to have installed one when doing the R-134a conversion). Charging can be accomplished by making the hook ups on the compressor and running the refrigeration harness hoses under the nearly closed decklid and hanging the harness manifold outside somewhere. The engine speed is kicked up to 2000 RPM to ensure adequate air flow through the decklid condenser and adequate compressor speed.
WPOZZZ 07-29-2006 07:46 PM
Good to know. Thanks.
pmajka 07-30-2006 06:59 AM
sorry for delay, email was out.
Questions for you; when you say "Vent temp is down to 50F when it was 93F outside...After driving for 15 minutes".
1 red
2 coupe
3 1
4 90% Humidity
5 speed 3 / 4
6 Uh...Envirosafe gave me one with a 5" stem, i slid it into the vent.
7 Ambiant temp was around 70 degrees in cab
msk1986911 07-30-2006 11:13 AM
Is anyone familiar with the product "auto a/c recharging kit for dummies"? My local Pep Boys has it on sale for $14.99 after rebate. If not for it being co-branded with Castrol I'd run the other way. Or, would you have to be a complete dummy to consider using this product?http://forums.pelicanparts.com/uploa...1154283179.jpg
Jim Sims 07-30-2006 01:28 PM
The problem with that "one sided kit" is that is you still won't know very well what's going on in terms of the charge. The gage appears very generic (no pressure numbers?) and you're only measuring the low side. The correct pressures (high and low) depend on the air temperature going into condenser and the temperature of the air coming out of the evaporator. If you're willing to spend $112.00 plus shipping you can get a decent refrigeration harness and refrigerant dispensing valve and do a much better job. You'll also need safety goggles and a couple of thermometers.
Harness: Mastercool 84772
Dispensing valve: Mastercool 85510
http://www.sjdiscounttools.com/mas84772.html
http://www.sjdiscounttools.com/msc85510.html
http://www.sjdiscounttools.com/kdt2054.html
http://www.sjdiscounttools.com/rob50945.html
msk1986911 08-03-2006 06:18 PM
Yet another A/C question. About 3 weeks ago, when I was replacing the decklid shock, I noticed what appeared to be oil on the rear of the car, just below the rear window. The marks were adjacent to the hinges for the decklid. After that, when I ran the A/C (in a vain attempt at overcoming the 95+ degree heat in the mid-atlantic region) I noticed that the compressor is louder than normal. Is this indicative of either the oil having drained (in which I have to find that leak) or, is the compressor about to give up the ghost? Is the compressor salvageable? Could I try a simple recharge with R-134 and ester oil?
Hugh R 08-03-2006 06:44 PM
Mine slings that oil as well, but its held a charge for around a year. It means the seal is going out. If you had r-12, you want to read a whole bunch of threads by Jim Sims on what to do to convert. New Receiver/Drier, probably new hoses, etc.
msk1986911 08-03-2006 06:50 PM
What are the "does and don'ts" of a home charge kit? Is it as simple as reading the pressure and filling it till it it reaches the recommended level?
ruf-porsche 08-04-2006 09:19 AM
Do read all the instruction before using the product.
Don't over fill the system.
DB_NC_95C2 08-04-2006 09:41 AM
I just ordered the 'kit minus compressor' from Rennaire. I finally had read enough and talked to them I had to throw the switch. I converted from R12 to R134A last summer, new compressor, new receiver. Problem was I really should have done EVERYTHING at once. I recharged the R134A this spring but this NC summer combined with the old hoses have done it in. I have enough to make it into September most likely when 3-60 A/C (2 windows and a sunroof @ 60mph) will be enough. Next spring (I know, why order the components now? because of the pricing) I'll replace the receiver/dryer with Rennaire's ProCooler, replace the stock evaporator with theirs, and the hoses (theirs will go in easier, smaller diameter). I figured while tearing stuff apart to do the hoses I might as well put in the best components. I've read enough kudos about them here and on rennlist with their customer success in Texas and Arizona....
Some might ask why go to the trouble with an 83 SC ? Because they'll bury me in this car, I love it (especially now that my county no longer has sniff tests, cat went buhbye and replaced by Fabspeed premuffler, stock muffler went buhbye and replace by Dansk single in,single out. Next year comes SSIs and 2-in-2-out Monty or M&K
bigchillcar 08-06-2006 10:30 AM
be very careful with 'home a/c' work, fellas...can be very dangerous. read up on all the threads about it before trying this work yourselves. please.
ryan
1974carrera 11-09-2006 06:04 PM
DB_NC_83SC , have you installed your Rennaire kit minus the compressor yet. I'm wondering what your experience is>
