-   -   mating engine and transaxle (http://forums.pelicanparts.com/porsche-911-technical-forum/293563-mating-engine-transaxle.html)
slotcar 07-15-2006 12:01 PM
OK...I'm as physically tired as I've ever been while working on the car. I've tried to mate engine and transaxle...and it won't happen. I just read a couple of posts from the search, but I wanted to ask a couple of questions.
Should I use a little moly grease on the inside lip of the TO bearing...where the input shaft cover slides...I only greased the input shaft itslef?
http://forums.pelicanparts.com/uploa...1152993492.jpg
Should the input shaft cover get greased on the outside?
http://forums.pelicanparts.com/uploa...1152993582.jpg
I'll also try turning the crank, maybe that will help?
slotcar 07-15-2006 12:21 PM
I got it!!!! Thank you Souk for your response in older post... mated it up, after I made a little progress I turned the crank just a little and it eased a bit more...turned the crank a little bit more and presto....!!! Oh, and the clutch fork is seated properly in the TO bearing groove....this forum (and the search function) are the best....:)
I didn't use any grease on the sleave or the TO bearing...I didn't want to from the begining since I know too much grease will kill my new clutch plate.
yelcab1 07-15-2006 12:51 PM
you should have some grease on the input shaft !
slotcar 07-15-2006 02:31 PM
I put some on the shaft...thanks.
