fred cook's Avatar
Cool It's all better now.............
The shifter, that is. I just replaced the shifter cup bushing, the shifter rod bushing and the coupler. Now I can actually get into first and third gear without reaching into the trunk! The old bushings and coupler (probably original) were toast! After 26 years and 123,000 miles it was time for some new pieces. The hardest part of the job is removing and replacing the console. Being equipped with a/c did not help a lot either. At least the carpets and console all got a good cleaning and vacuuming. The step by step instructions in the tech article section was a big help. Now I know it won't be a big deal if I decide to add a short shift kit. I even found some change when I had the carpets out! Total time for the job wound up being about 2 1/2 -3 hrs including breaks to play with the dog.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-06-2006, 07:18 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Fred - did you lubricate the cup and bushings as you installed them?
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 09-06-2006, 07:30 PM
fred cook's Avatar
Cool Shifter bushings.......
Yes. I used some special Dow lubricant that is used on aircraft engine seals (provided by a friend in the business). It is a thick, almost white silicone based grease that I have used for various applications over the years. It seems to work well when used on the lips of new engine seals and on O rings installed during rebuilds. Plus there was a small amount of residual "slickum" on the shifter shaft. Everything seems to be happy and working as it should.
FEC3
Old 09-07-2006, 04:01 AM
