another round please
strupgolf's Avatar
How big a spark should there be?
Searched but didnt find. I'm trying to find a miss of my 86 3.2 911. I pulled the plug wire off and installed a good plug into it, held the wire, and started the motor. How big a spark should there be? It is so small that it's hard to see the spark. I thought there should be a big bright arching spark but no. Any ideas on this. The rotor and cap seem to be fine and fairly new. Oh, and when I hold the wire, should I hold it to a ground, or just let it lie on a towel. Thanks
Getting old is not for wimps.
Old 07-18-2006, 06:02 PM
Early_S_Man's Avatar
Porsche Crest
Here is the test spark plug I recommend ... and, YES, it should be grounded!
KD Tools 2756 or 2757:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-18-2006, 06:21 PM
defcon65's Avatar
Sparks should be bright and blueish, visible in daylight. Reddish to yellow can indicate a weak coil or ignition module. Check the ground connections too, that can cause a miss sometimes.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 07-18-2006, 06:55 PM
strupgolf's Avatar
I could barely see the spark at dusk, but again they were'nt grounded like Early s said. I just held the plug wire with a channel lock with a new spark plug attached to the end. At start-up, it really POPS loudly, and then calms down some. But its still there when driving. Where should I check for the ground connections?
Old 07-18-2006, 07:26 PM
A good spark should be quite audible too. A loud snap is good.
Sherwood
Old 07-18-2006, 08:30 PM
The spark should jump at least a quarter of an inch to ground. You can check other cylinders to compare.
-Andy
Old 07-18-2006, 09:14 PM
lateapex911's Avatar
Well, if the plug isn't grounded, the spark isn't going to be very strong, LOL. Test again, but with the plug grounded. Imperitive.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 07-18-2006, 11:10 PM
defcon65's Avatar
Strup, you can check the ground strap from the engine to the body and see if it is loose or corroded but from your description of a weakening spark, it's probably the ignition module in your 86. Test the spark by laying the metal body of the plug against a good ground, like a metal engine component when you crank the engine. A miss could also be a bad fuel injector, though - have you had those tested/cleaned? Is the car high-mileage?
Joe
85 Carrera
Old 07-19-2006, 07:17 AM
Senior Member
Superman's Avatar
I'd pull the wire from the center of the distributor cap and hold it (using insulated pliers) near a metal engine part. Have someone turn the engine over. The spark should be blue, snappy and should be happy to jump at least a half-inch. I've seen them jump more than two inches.
Mocha 1978 911SC. "Coco"
Old 07-19-2006, 09:08 AM
defcon65's Avatar
I checked Pelican's parts catalog and it looks like the factory ignition unit is not available for your car if it is indeed bad. You might try the aftermarket MSD ignition; a lot of Pelicans use those.
Joe
85 Carrera
Old 07-19-2006, 11:04 AM
strupgolf's Avatar
Thanks for the help guys. Yea, it SPARKS when you ground the plugs. I get good spark to all plugs so I dont think its the wires, great!!. Now, I've run a can of FI cleaner for about a hour, but it still POPs. How do you check for a bad injector, it could be that.
Old 07-19-2006, 03:12 PM
"How do you check for a bad injector, it could be that."
To help isolate a weak, non-contributing cylinder, perform a cylinder balance test. With the engine at a high idle, disconnect a spark plug wire one by one and note how much the engine speed drops each time. The cylinder that drops the least is the one not contributing. That could be due to a bad plug wire, poor cylinder compression, bad plug .... perhaps a faulty fuel injector. Don't run the engine too long with a disconnected plug wire - it puts a strain on the ignition system if the 15,000 volt spark can't find a ground. Unburnt fuel also collects in a disconnected cylinder.
You can perform the same test by disconnecting each injector harness connector in turn. That might isolate a faulty injector. Swap injectors in cylinders and retest.
Sherwood
Old 07-19-2006, 06:50 PM
