Question Inner door handle rod
I was doing some drivers side door maintenance today, fixing window switches, mirror switches,cleaned the leather on the door panel, stuff like that. When I was reassembling the door panel I decided to adjust the inner door handle threaded rod because the inner door handle was sticking out a little to much when I went to turn the turn buckle I broke the inner threaded rod, upon further inspection it appears the PO crimped the turn buckle on the inner rod, maybe due to damaged threads. Now I need to find a new inner door handle rod, but I can't seem to find one. Anyone now of where I can get one?
Old 07-15-2006, 04:08 PM
Nine9six's Avatar
For used parts, try Parts Heaven in Hayward, CA. 510-782-0354 or info@partsheaven.com
The guys there are good folks and have helped me many times with both new and used parts.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 07-15-2006, 04:15 PM
Thanks Nine9six, I'll give them a call
85' Carrera
92' Mustang 5.0
02' Focus ZX3 08' FJ Cruiser
Old 07-15-2006, 04:24 PM
goldgunner's Avatar
That crimp on one end of the tiny turnbuckle is standard as factory furnished. Arranged so that only the other end turns and is adjustable.
It's called a 'Pull Rod' and may be different lengths depending on the model year. P/N is: 993.531.091.01
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 07-16-2006, 05:00 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
If Parts Heaven doesn't work out, you can call our host and ask if they carry them (sometimes they carry parts that are not in their online catelog) or if they can obtain one for you. Another option is ordering it from your local dealership, sometimes there is a long wait (a few weeks) for them to get the part from Germany.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 07-16-2006, 06:44 AM
goldgunner's Avatar
Pelican does supply this item - just takes a few days or so for them to get in from Porsche and ship.
Old 07-16-2006, 06:47 AM
Thanks guys for all your help,ordered the part, its on the way,(well, it will be tomorrow).
Old 07-16-2006, 10:33 PM
