Huey58
Guest
Posts: n/a
Tail removal
I would like to remove the whale tail on my 86" cab. It looks like I have to remove the Oil cooling system mounted under the rear engine cover. This system is pressurized and I don't want to screw something up. Any suggestions?
Huey58 @NetZero.net
Old 01-01-2000, 12:09 PM
Charlie Moore
Guest
Posts: n/a
The unit mounted on the underside of the engine lid is one of the condensors for the a/c system - yes it's pressurized - with freon.
When you remove the whale tail you'll be left with about 10 1/4 inch holes in the engine lid. Probably the easiest thing to do would be to get another lid from a salvage yard (in the same color) otherwise you'll have to have all these holes filled and have the cover repainted.
Are you sure you really want to remove the tail?
Old 01-01-2000, 04:37 PM
