Wider is Better
Fire Extinguisher Mount
After seeing what was available for extinguisher mounts, and the outrageous prices for some of them, I decided to see what I could do on my own.
I started with some aluminum bar stock I had sitting around, After a little bending, drilling, aluminum paint and 3 coats of spray on clear coat, and then mounting the extinguisher mount, I had this: I removed a small section of sound insulation, cleaned the areas good with lacquer thinner to get any residue off, and glued some industrial strength velcro to the body, then mounted the bracket. A couple of small slits in the carpet and voila! With the extinguisher in: Front view I used industrial velcro because I wanted to avoid drilling into the body. If it does not hold well, I will probably go ahead and put a couple of screws in to hold it, but I am hoping that the velcro, combined with the carpet glued down on top of it, will be adequate. Best of all, it is easily accessible and does not interfere with the rear passenger seats. Total cost: $12 for velcro, I already had everything else. The fun of doing it: For me, priceless.
Wider is Better Last edited by wholberg; 07-16-2006 at 11:21 AM.. |
Projects like this sure are rewarding, nice job.
I would definitely put some screws in...don't forget that in an accident that would become a lethal projectile. I'm not familiar with industrial velcro but it's hard to imagine it could stand up to the unpredictable forces of a crash or roll over. |
I second on bolting that puppy down. Velcro is not going to hold in any kind of accident.
87 Targa. It's completely stock. honest. |
UFLYICU
Looks like it would be simple to modify it to mount it to the plate that covers the shifter coupling, which would eliminate drilling through the body. I like the location, and that it leaves the rear seats accessible.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Wider is Better
Wider is Better |
That's why you have us
UFLYICU
The simplicity is what impresses me the most. Outstanding idea which will certainly be copied by others. Great job.
what is the color name of your interior?
87 911 coupe "Katy" Summer Yellow Linen Mahogany interior 04 Pilot "The Pilot" |
UFLYICU
Looks like Linen to me.
Wider is Better
Zoanas has it right. It is a linen interior. The front foot is on the shifter coupling cover so that will be easy. The rear one will require a drill bit and a couple of self tapping screws and some silicone. What is under that short vertical section of sheet metal?
And one more thing, I have heard people talk disparagingly of the sound insulation, but I has no idea is was as thick as it is. How much does it weigh throughout the entire car?
Wider is Better |
I also built my own. Instead of cutting carpet and stuff, I took a piece of drilled angle iron. Mounted the extinguisher bracket to the angle iron and then used the two front bolts of the passenger seat sliders (one on each side) to mount it. The end result? A great mount that could be easily removed and required no additional "modifications" (read=damage) to the interior. it was accessible to the driver and if I had an instructor in the car, it didn't interfere with their legroom either. I'll see if I have any photos.
J-RAD 2006 Boxster S 2000 Boxster S 1982 911 SC Euro Last edited by J-RAD; 07-16-2006 at 07:09 PM.. |
Somatic Negative Optimist
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
UFLYICU
Why not use a longer piece that would wrap all the way around so the ends meet, and attach it to the coupler cover. It doesn't need to tuck under the carpet at all.
Wider is Better
Wider is Better |
I put mine behind the driver seat- at 6'5" no one is ever sitting behind me anyway. I have practiced the seat pop, extenguisher pull, engine release pull routine to make sure I have it down.
#29 SCWDP (muhaahhh!!)
IslandmanFL SOLD...78 911SC (ROW) cabriolet/widebody hear BEBE purr!! 92 325is Now living in Sunny West Palm Beach FL! |
