Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Decolliber's Avatar
Damage from leaving ignition on?
Left the ignition on in my Carrera for two days. Battery is flat and I am recharging it now. Is there possible damage to anything else beyond the battery? I seem to recall reading a long time ago that the coil can be damaged. Is this true? If so, how can I test the coil, aside from just seeing if it produces enough voltage to start the engine?
John C
1988 911 Carrera coupe
2002 BMW 530
Old 07-17-2006, 05:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
no hard info here.
just as a data point. Some pelicanheads reported toasted Pertronix with key left in on.
search w/ Early_Man
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-17-2006, 06:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
MRM MRM is offline
Shouldn't affect your car. Electronic ignitions shouldn't do anything more than drain the battery.
MRM 1984 Carrera Cab Eurospec
Old 07-17-2006, 06:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
wcc wcc is offline
wcc's Avatar
+1
Bill
Old 07-18-2006, 04:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
+2
Old 07-18-2006, 07:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Senior Member
Early_S_Man's Avatar
Porsche Crest
John,
If your coil got hot enough to damage it ... it will most likely be 'oozing' now ... check for oil or goo leakage.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-18-2006, 07:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Decolliber's Avatar
Thanks for all the reassuring responses. The coil seems fine and I drove the car to work today. My only concern now is whether the Optima battery might have been damaged from being deeply discharged, but since it held a charge over-night I guess its fine. A few years ago a Pelican posted here that his Optima was unable to hold a charge after being allowed to fully discharge.
John C
2002 BMW 530
Old 07-18-2006, 07:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
