frankoporsche
Guest
Posts: n/a
Valve adjustment
A few a day ago my 86 911 valve tapping very loud and i took off the intake valve cover off and there was a huge gap between lifter and the valve . so I made adjustment and there isn't much thread left for the nut.
the cam seem be fine. Never had this probelm before.
Old 12-31-1999, 12:00 AM
Early_S_Man
Guest
Posts: n/a
That sure sounds like a bent or 'stuck' valve to me. If you look at a cross-section drawing of the head, all possible worst-case wear conditions were taken into the design, without running out of threads on the swivel-foot adjuster!
You should perform a compression test on that cylinder ASAP! My bet is you will have ZERO compression on that cylinder, because that intake valve is probably stuck open!
Warren Hall
1973 911S Targa
Old 12-31-1999, 10:46 AM
frankoporsche
Guest
Posts: n/a
Thank you Wayne I'll check the compression
test and see what happen and I'm hopin you're right. Will get back to later next week. Franko
Old 01-04-2000, 09:44 PM
