slodave's Avatar
Hydraulic chain tensioner question
Hi!
While removing my engine for a second (unplanned) time, I noticed that there seems to be some oil leaking around the chain tensioner covers. I know what happens when things fail in there, so we don't really need to go there. I did not think to take pictures of the area, but can if needed. Could the gaskets just be leaking? What about the lines that feed the tensioners? Is it an easy task to replace the tensioners? Yikes, I see that tensioners cost $231.00. Man, I really can't afford this right now!!!! But, I guess if they fail, I will have to spend a lot more than that.
Thanks!!
Dave
Old 08-24-2006, 10:36 AM
Replace the leaky gasket.
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 08-24-2006, 10:53 AM
slodave's Avatar
Hmmm.... Can it be that easy and cheap? I can afford to do that. Thanks!!!
Dave
Old 08-24-2006, 11:02 AM
fairly easy to replace the o-rings that go between the tensioner and cover plate... a word to the wise... in some "rebuild" kits you get o-rings that are undersized... they may seal ok or not... viton is a good material for that application... you want to feel a good compression as you put the plate on...use a bit of oil or grease on the surfaces .. I'm sorry I now don't have the dimension details.
Sold: 1989 3.2 coupe, 112k miles
Old 09-02-2006, 08:15 AM
Somatic Negative Optimist
Gunter's Avatar
Dave:
Before you change the gaskets make sure that the 0-rings seal properly.
Get new ones if necessary.
If you get new gaskets, clean the case, and cover, real good.
Then, apply a thin cover of anti-seize lube to both sides of the gaskets before installing.
It's an old trick we use in industrial applications; it means that you never have to clean/scrape the surfaces again to remove parts of the gaskets.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-02-2006, 08:47 AM
slodave's Avatar
I have decided to put this off for a few months. The area at the bottom of each cover does have oil/dirt around them, but it does not seem very fresh. I have to replace my cat in a few months anyway and I believe I will have more room to get at them. I am also tired of the current project. It has gone on too long and I want my car back. If it looked bad enough or if I had noticed a huge puddle on the ground under them, I would o it now.... I will refer back to this thread, thanks for all the help and ideas!
Dave
Old 09-02-2006, 07:25 PM
