bonaturtle's Avatar
Send a message via ICQ to bonaturtle Send a message via AIM to bonaturtle Send a message via Yahoo to bonaturtle
Any local Chicagoan help out a fellow 911 guy...
trying to figure out why my driver's side power window doesn't work. I have a new switch and motor in hand, tried the switch, nothing happenned.
I also read there is a relay behind the oil gauge, but I'm still a nOOb at this. Anyway someone could test my window to figure out if it's the motor?
TIA
Sean
1988 911 Coupe Blk/Linen
1992 Mercedes-Benz 190 2.3
1999 Honda Accord LX
2003 Kymco People 50 (city killer)
Old 07-14-2006, 02:13 PM
ruf-porsche's Avatar
Cool
Did the window ever work before?
I'm in the south loop area. Where are you located?
Old 07-14-2006, 04:04 PM
Guy I knew had an old Honda with a bad window switch. He always forgot about it so whenever he rolled the window down it wouldn't go back up. Would take a couple of long wires and connect the window motor directly to the battery to shut it.
Old 07-14-2006, 05:48 PM
bonaturtle's Avatar
ha, I'm in River West, and it did work about a week before I purchased the car, and then died during the PPI, thank god it was up.
Sean
Old 07-15-2006, 06:44 AM
bonaturtle's Avatar
bump
Sean
Old 07-17-2006, 06:46 PM
I recently replaced my driver's window motor and got the old one to work after the fact, so now I have a spare I guess.
Check your owner's book there might be a procedure to manually open the window and break the motor loose.
In my '92 you remove the tweeter speaker, slit the plastic and insert a 5/32 Allen wrench all the way thru and attempt to turn the motor, lowering the window.
I really needed to replace the motor anyway, so now that window is just as quick as the car.
Mark
'92 964
Old 07-17-2006, 08:47 PM
bonaturtle's Avatar
Don't want to open up the door if I don't have to, and there must be power coming from somewhere, seeing I get sparks when I'm reconnecting the switch.
Sean
Old 07-18-2006, 06:41 AM
Do you have the right wires connected to the switch?
Old 07-18-2006, 03:29 PM
