Nine9six's Avatar
Valve cover gasket set recommendation needed
Can anyone recommend one type of valve cover gasket set over another?
Some gaskets have the silicone bead around them, others are graphited. Can any of you gurus call out a preferance and explain why?
Thanks in advance...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 07-21-2006, 06:31 PM
gray uppers and lowers. they're thick, so they take up most surface irregularities in the covers. silicone rubber ones are kind of wierd, being that you can't really tighten them much or they will squish out.
206 637 4071
Old 07-21-2006, 07:16 PM
19 years and 17k posts...
azasadny's Avatar
I used the gaskets with the silicone bead and never had a leak in three years.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-21-2006, 08:11 PM
The intake ones don't matter-anything will work. For the exhaust I highly recommend the green ones with the silicon bead around them. I've never had a leak with them. The pure silicon ones that JW is talking about can be hard to use and I don't like them. As he said they tend to squish out. Others have had good luck with them however and they are reusable.
The last couple of kits I bought had gray graphite uppers and the green lowers with the silicon bead. I ask for these now whenever I order.
-Andy
Old 07-21-2006, 08:52 PM
Unregistered
sammyg2's Avatar
red silicone gaskets on the lower. If installed right they will cover up many other flaws (warped covers) that the other gaskets won't. plus they are re-useable. All you have to do is clean the surfaces and the gaskets and tighten them down a little bit. Not alot, only about 3 ft. lbs.
Old 07-21-2006, 09:12 PM
Blanco's Avatar
I've had excellent results with the gaskets from this outfit.
http://www.realgaskets.com/
They supply porsche gaskets here.
http://www.realgaskets.com/files/automobile.htm#porsche
I've had them for a year now and nary a drop of oil if torqued correctly. And they are also reusable.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 07-22-2006, 05:37 AM
