issue with sway bar installation
I recently installed a Carrera sway bar in the rear of my 76' S. I didn't recall having this issue when I first installed it..but!
The problem is that when I looked at the clamp that holds the bar to the body I see that the bushings there are squezzed out of the clamp. I adjusted the clamp bolts until the clamp touchs the mount on the body. Is this wrong? Should I loose the clamp bolt a little? I am assuming that the clamp will be the same for the carrera bar (21mm) than for the stock (18mm). Is this correct? Thanks |
Mario,
The rubber bushings are different sizes, bigger hole for the 21mm vs the 18mm. The clamps are the same. |
| All times are GMT -8. The time now is 08:12 AM. |
