goldgunner's Avatar
84 Carerra Throttle Body Threaded Port - ??
On an 84 Carrera throttle body, the side toward the back of the car, next to the adjusting screw, is a threaded port as arrowed in the following photo.
What is this port 'usually' used for?
And if it's not used for that - does it need to be sealed off? (Will it leak air?)
thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 07-20-2006, 01:02 PM
that hole is for the bracket that holds the off throttle micro switch connector
probably in another baggie filled with nice shinny parts?
edit, no it won't leak if you're not using an idle switch
Old 07-20-2006, 01:24 PM
goldgunner's Avatar
Nope, Jerry - not using that: mine's a Clewett - Electromotive EFI conversion, so I'll just ignore it...thanks to your elucidation!
Thanks again,
Jim
Old 07-20-2006, 01:35 PM
how about a full engine pic?
Old 07-20-2006, 01:38 PM
goldgunner's Avatar
Uh..ok...
I'll make a new post so that it's easier to load pics, and title it...
"If It Runs As Good As It Looks"
Thanks for your interest,
Regards,
Jim
Old 07-20-2006, 02:13 PM
