Carrera/Turbo Tail Question
I have a turbo tail (the rubber happens to need replacing) and was wondering if anyone knows if I can use the Carrera tail rubber on this?
Mark '74 911S Coupe |
There was an article in Excellence a while back about a C4 that had this set up. The owner installed an aftermarket turbo in his C4 and had to use the turbo tail because a Carrera tail would no longer fit. He wanted to keep the look of the Carrera tail so he installed the Carrera rubber on a turbo base. It looked like a straight replacement. I will see if I can find the article tonight and let you know exactly what it says.
| All times are GMT -8. The time now is 11:20 AM. |
