-   -   Can CIS be used on an MFI motor (http://forums.pelicanparts.com/porsche-911-technical-forum/29448-can-cis-used-mfi-motor.html)
jabb 01-13-2000 10:57 AM
Can CIS injection be used in place of
MFI. Are the cams pistons and other engine
componets diffrent enough that this conversion could not be done on a 2.2E motor.
Lee Wister 01-13-2000 11:19 AM
Not very well. The cam shaft lift and duration will cause a intake pulse wave that will make the sensor plate osolate. This condition will create flat spots and idle problems. You best convert to Webers.
Good Luck,
Lee
