headlight relay kit
Does anyone know who might sell kits to wire in relays for the headlights?
Look here:
Sucro Relay Kit
"Igneous Aquam et Laudi semper" Carl Muckley |
UFLYICU
Do a search on my username and "relay setup". I installed a six relay setup that I've found to have all the flexibility I was looking for. Independent fogs, separate hi/lo circuits, high wattage capability, easy troubleshooting, and it isn't likely to fail in a way that I lose more than one filament.
Here's my initial thread. There was a lot of discussion over the different methods, and whether mine was overkill, but I've been using it for awhile now, and I haven't had a single problem, and I work shiftwork, so I do plenty of night driving. With the six-relay setup, and Hella 450 driving lights replacing the fogs, you would not believe the amount of light the car puts out.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Thanks for the links and info, much appreciated!
Guest
Posts: n/a
From the 911S website. I installed one with my H-4's. Easy and works great. Also a good value.
http://members.rennlist.com/msucro1/relaykit.htm Gary |
