Angry Stereo speakers whine need help
My stereo on my 2.7s works fine at rest but when the car moves i get a noise from the speakers and sometimes the stereo cuts out but if I slow down its fine!!!!! I have checked all the connections to the stereo and as a precaution changed all the wiring joints. I am at a wits end. Is it a ground? and where do i look any help would be greatly appreciated
Regards
Adrian
Old 07-20-2006, 07:14 PM
randywebb's Avatar
Does the whine vary with engine speed?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-20-2006, 08:03 PM
gliderguy's Avatar
are you running a amp or deck power? Ground could be a culprit.
If you are not running an amp and you are cutting out at speed are you turning the stereo loud to compensate for road noise? deck may be getting to hot.
76 911/2.7/SSI/2in 1out/tensioners/Ice Green Targa
01 Suburban
02 Jeep Liberty
WillsWings Eagle
"As I hug the mountain tops in my hang glider, the only distraction Is looking below at the roads I will hug with my 911 "
Old 07-21-2006, 08:23 AM
No amp but the whine has become intermittant and only occurs when I accelerate. I am going to check the ground and will let you know if it solves the problem
Old 07-21-2006, 08:28 AM
Early_S_Man's Avatar
Porsche Crest
While you are troubleshooting ... monitor your system Voltage for a ride or two and check it when the audio trouble shows up! Sounds like alternator-induced noise to me. A flakey Voltage regulator could be sending out distress signals ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-21-2006, 08:38 AM
gliderguy's Avatar
maybe it is only audible during acceleration. Is your power wire running straight to the battery or thru cars electrical system. dedicated ground wire and hot might help.
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-21-2006, 09:00 AM
