in dash relay question. Please read
Taking off the most left gauge I saw 2 tall square relays right there but there are total 3 holders in line (there is another smaller relay behind but can't see). I think I am missing the right most relay. Anyone know what is that relay for?
Thanks. http://doublehretail.dynalias.com/ca...r_Front_01.jpg |
Seat belt buzzer?
Tim |
Thanks for response Tim,
It the thrid one counting from left toright (last one). Is it the seat belt buzzler? Meaning if I have the relay there and seatbelt off, it will buz? If it's not there, circuit is opened? In that case, I'll leave it off. Thanks. |
caveat - this info based on my 81.
The seat belt timed buzzer relay sits on a little black plastic platform. behind the guage. if you turn key on and get no seat belt light/buzzer or leave doors open with key in ignition and get no buzzer , that likely means you have no seat belt relay installed - a very popular removal since the buzzer is annoying. With the relay installed you should only get 'buzz' for approx 6 seconds when starting car if drivers side seat belt is not fastened. However the sound has been described as 'the most annoying sound in the world' or similar a baby screaming. I have my relay installed and those decriptions are pretty much true. |
Thanks for info.
Talking about open/close doors, just remember my door switch doesn't connect to anything. I think it suppose to connect to at least the dom light. Anyone know where the connector between door switch wires and dom light wire located? Thanks. |
| All times are GMT -8. The time now is 12:06 AM. |
