I prefer the 3M #8008 Black Weatherstripping Adhesive to the #8001 Yellow. The one ounce tubes carded for general use [Hobby Lobby] seem to be the same product as in #8008 five-ounce tubes.
http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_GSTVNWY1SBgs/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/bgel_GSN61N466Bbl/gvel_Q5D2V4SCM0gl/theme_us_aad_3_0/command_AbcPageHandler/output_html The Permatex Black Rubber Sealant is also good. Freshly applied excess, squeezed out, or strings, can be removed with Brakleen and a paper towel. http://www.permatex.com/products/automotive/auto_adhesives_sealants/sealants/Permatex_Black_Rubber_Sealant.htm http://www.permatex.com/documents/tds/automotive/80338.pdf |
I've used the 3M spray adhesive with more success. First turn the felt piece to the side you want to adhere and spray throughly. For the body side, spray into a paper cup and use a small arts type paint brush to paint it on the area. It flows very easy. Then wait 5-10 minutes until it is tacky then carefully place in the correct areas. It dries relatively clear and any material left can be gently "rubbed" away.
| All times are GMT -8. The time now is 07:13 PM. |
