-   -   Targa Window Corner Seal (http://forums.pelicanparts.com/porsche-911-technical-forum/29469-targa-window-corner-seal.html)
placerville 01-17-2000 09:56 AM
I've got a 74 911 Targa and I'm replacing all the weather-stripping around the windows. On the top of the vent window frame is the corner seal - which is riveted to the vent window frame with some copper or brass rivets. These are not pop rivets. Any ideas/suggestions on how to install the new rivets? Thanks in advance! Mike
Early_S_Man 01-17-2000 07:01 PM
I replaced those same two pieces on my '73 a few years ago, drilling out the old rivets, and using a self-tapping screw in their place, with carefully filed down screw tips for minimum intrusion and clearance problems.
Warren Hall
1973 911S Targa
Seven-Seven 07-28-2002 10:27 AM
Self-tapping screws
Warren --
I know that it's been many years now since you replaced the rivets with self-tapping screws, but do you happen to recall what the screws were made of (i.e. brass, stainless, etc.) and whether the threads were coarse or machine-like?
I'm looking at the same repair work right now and I want to try and get this right the first time.
Early_S_Man 07-28-2002 11:40 AM
Carlton,
The screws I used were just zinc-plated steel from a local hardware store ... probably not the best solution. The threads were coarse, probably intended for sheet metal use. I believe the window frame is chrome-plated brass, so not a lot of tolerance for error is present!
I suspect that a pop-rivet gun with an extended nosepiece and copper pop-rivets would be closest to the ideal solution. But, I haven't had any problem with my 'expedient' solution coming loose, either!
Peterfrans 07-28-2002 12:37 PM
I bought the original rivets from my local p-dealer, put a fitting piece of metal in my benchvise and with a hamer and punch flattened the rivet. As the copper is relatively soft it was very easy to come up with good results.
Seven-Seven 07-28-2002 03:55 PM
Based on Warren's note that riveting might be "ideal" and Peter's success with using the factory rivets, I'm going to take a stab at riveting the corner back in place, possibly with (factory) copper rivets if I can get my hands on them.
Since I decided (just last night) to send the quarter-window frame out for powder coating, I have a few days in which to find the right materials and tools.
Thanks for the info! SmileWavy
