Help! gearstick/shifter loose, 996 turbo
While driving my 996 turbo 2003 model today, I was starting the car as usual in first gear, and was shifting to second gear when the shifter suddenly felt loose, with no resistance when moving in between first and second gear. It was stuck in first gear, and it is not possible to shift the shifter sideway like you do to move the stick to the right to go from second to third or forth gear. I took of the leather "bag" and trim ring and looked down at the gear shifter assembly. The shifter is attached to some plastic pieces and has a metal bolt that holds it in position. What I suspect is that a connection below the assembly that is not visible, at the end of the metal shifter rod (at the bottom end of the shifter rod) has a cable or link rod that has come loose. I tried to loosen the trim plates on the side of the console to have a look under the shifter assembly, but that did not help the visibility. Is there a easy way to fix this or do I have to drive the car in first gear all the way to the Porsche shop?
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 07-22-2006, 08:02 AM
DavidI's Avatar
Zithlord, this BBS is mostly frequented by owners of older Porsches. To get an informed response, you may want to try Rennlist and post the question there.
Who knows though? There are many very experienced individuals on the BBS who may have the answer.
Good luck, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 07-22-2006, 08:23 AM
Europa Auto's Avatar
It's the gear shift linkage bushings that propably broke off, or the shift rod coupling. Replace bushings and or coupling and should be back on the road.
Mike
2002 996 911 Carrera Cab
1998 Boxster S
2002 BMW X5
1978 FJ40 Land Cruiser
2005 Jeep Liberty CRD - Diesel
www.europautoparts.com
Old 07-22-2006, 08:32 AM
